Old 04-13-2016, 08:34 AM   #1
WolfWhistle's Avatar
Drawtite / Reese Dual-Cam 1200# 12000#
The Drawtite dual-cam is complete with everything you need to install it. I has some wear, but plenty of miles left in it. With a toy hauler and differing loads, it was just much work changing the set up each time.
The 12,000# ball included.
I am showing closeups pics of the critical wear areas, one the top of the cams and the other where the bars sit in the hitch.
$200 local pickup only
I'm just south of Hilliard (US-1) and about 18 miles from I-95; close to the FL - GA line
I will be traveling beginning middle of May
Thanks,
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
WolfWhistle is offline
Old 04-13-2016, 10:40 AM   #2
Replying myself to add photos
I also wanted to point out the wear area: on the cam where the curves of the bars rest and on the pocket in the hitch where the bars sit.
You also might note that the hitch was also set up for the friction bar type anti-sway device.
ID:	104771   Click image for larger version
ID:	104772   Click image for larger version
ID:	104773   Click image for larger version
ID:	104774   Click image for larger version
Hyper Lite was sold
Old 04-19-2016, 09:12 AM   #3
Price too high? Make an offer.
WW
Hyper Lite was sold
