Old 01-30-2018, 10:30 AM   #1
Vince and Charlette's Avatar
[Need Met] - 4 TST TPMS Non-Flow-Thru cap sensors
I just had my third valve stem break off of my Jeep Liberty toad because of the length of the Flow-Thru TPMS 507 model. Part of the problem is also due to the valve stem position on my Jeep Liberty toad being so close to the outer part of the rim. It makes the 507 flowthrough stick out even further making it susceptible to being broken off if something brushes by it. (Yes, I already have the short valve stems on the wheel.) So, if you have four of the TST RV Cap Sensors (i.e. Non-Flow-Thru) send me a note right away. If the price is right, I might want to take them off your hands.
2018 Berkshire 38A
Vince and Charlette is online now
Old 02-01-2018, 10:06 AM   #2
Truck System Technologies Rep
Tst tpms
Hi Sir,
Do you have metal valve stems on your jeep?
Thanks,
Mike Benson
TST TPMS
210-420-0132
mbenson1234 is offline
Old 02-01-2018, 10:11 AM   #3
Brother Les's Avatar
Call TST and tell them your issue and they will give suggestions on how to have their system work better for you.
I go no where with out the sensors on my RV and tow vehicle.
Safety first and always.
Brother Les
Brother Les is offline
Old 02-01-2018, 03:17 PM   #4
Thanks to both of you. I talked with TST just yesterday. Their first suggestion was to change the 507 Flow-Thrus on my Jeep toad to Non-Flow-Thrus because they are shorter and lighter. They also suggested changing valve stems to stainless or rubber since the aluminum ones are incompatible with the brass TPMS stem since they are a "di-electric". (Need di-electric grease to resolve issue.) Since the stainless would still stick out, I went with the high-end rubber ones. Shortly after posting this message, I found a pack of four online and bought them for well under what TST wanted for them. Since my MH valve stems are stainless and well within the rim, I'm keeping the Flow-Thru on that vehicle. PS - I'll try to close the post.
2018 Berkshire 38A
Old 02-01-2018, 06:02 PM   #5
Mr. Dan's Avatar
I'll add [Need Met] in your title as our way of closing it.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Mr. Dan is online now
Old 02-02-2018, 11:51 PM   #6
TST TPMS
Glad you found the 4 cap sensors. If you have any questions programming them, or have a question regarding our NEW color wide screen display feel free to contact me anytime at 210-420-0132
Thanks,
Mike Benson
TST TPMS
210-420-0132
tpms
