Old 03-28-2015, 01:33 AM   #1
Tyler & Connie Foxx
FoxxLandArk's Avatar
P2 Tekonsha Electric Brake Control System - $75
Pre-owned Tekonsha Prodigy P2 electric trailer brake control; includes new 3' pigtail harness kit, mounting bracket and hardware, and installation DVD
* Reverse battery protection for both vehicle and breakaway
* Designed to work with electric over hydraulic brake systems
* Numerous mounting options - including 360 degree vertical rotation
* Digital display depicts voltage delivery to trailer during braking
* No level adjustment necessary - it adjusts itself to varying terrain as you drive
* Great for backing into tough spots! Works proportionally in reverse with the ability to disable when not needed
* Produces stops that are in proportion to vehicles deceleration rate
* "Boost" feature gives users the ability to apply more initial trailer braking power when towing heavier trailers
* Continual diagnostics check for proper connection, shorted magnet conditions and much more
* Quick and easy disconnect feature allows user to remove and store the control when not in use
* Electric trailer brake control for up to 4 braking axles
Reason for selling: upgraded to P3 model. Sold as is and without warranty.
Interested? PM me please. Thank you.
Sent from my iPad2 Air using Forest River Forums
FoxxLandArk is offline
brake control, electric, brakes
