Old 07-26-2016, 03:05 PM   #1
Reese 20K Titan Fifth Wheel Round Tube Slider Unit
$250 obo
This slider was only used about 6 times. I discovered I didn't need it and went with fixed arms.
Reese Model 50024
Up to 20,000 lbs.
10" travel rearward from center of rail
Current slider systems expanded to give true ease and precision
Embossed roller supports for low friction and longer wear
Forged mounting feet for wide consistent attachment to rails
Updated pin mounting holes to better align with the current rail kits and reduce play
Plated rails hold up longer for extended wear
ID:	115386   Click image for larger version
ID:	115387   Click image for larger version
ID:	115388   Click image for larger version
JConti is offline
fifth wheel, slide, wheel
