Have a Short bed truck? Want to tow a fifth wheel, but don't want to spend a ton of money on a sliding hitch system?! Well, The Reese Sidewinder 5th Wheel Pin Box, completely eliminates the need for a sliding hitch!
Buy a gently used Sidewinder for less than half the price of new. - $450 or reasonable offer (Pickup only in Spotsylvania, VA)
Check out this video for a demo of features and use.
Information from product tag:
Model: Sidewinder
Max Trailer WT: 16,000lbs
Max Pin WT: 3,200lbs
Part No.#: SW16K
Date of MFG: 07/15/10
Information from Reese website for newest models:
Reese - Sidewinder)
Reese Sidewinder, with a limited lifetime warranty, is the premium pin box designed specifically for short bed pickups. The nimble and quick design automatically eliminates turning and clearance headaches. Now you can make up to 90-degree plus turns without exiting the truck. Without throwing a switch. Without pushing a button.
Note Not all tow vehicle and trailer combinations will allow 90-degree turn
Sidewinder's king pin locking mechanism moves the pivot position 22" rear of the pin box's attachment point. This enables Sidewinder to handle up to a 90-degree plus turn effortlessly. By moving the pivot rearward while keeping the load centered over the axles, the trailer tracks more closely to the truck. This reduces the need for extra-wide turns and allows short bed pickups to jackknife with no fear of contact. And it's all done automatically. Sidewinder also offers faster steering wheel response, making backing up easier than ever before. The pivoting pin box makes hook up possible at any angle. And since the towing position of the pin box arm is locked in line with the truck, you can make full use of the truck bed space, giving you extra storage space for fuel tanks, toolboxes and cargo.
Don' let the slim looks fool you. Sidewinder has been built for strength. The C-channel design gives it more stability and strength than the standard pin box design. It also allows better load capacity and the ability to support heavier loads. Tested for real world conditions, Sidewinder has cleared rigorous testing by BOSCH automotive proving grounds and exceeds all SAE/CSA Standard 16K ratings requirements for RVs.
