Roadi RDT51 OBD 2 Scanner
Hi,
This is an as-new OBD2 scanner, as described below from sales literature.
"Roadi Diagnostic Trouble Code Reader comes together with an upgradeable through computer USB for new models vehicles, specifications and updated diagnostic trouble codes.
This is for the average guy who does it himself fixer uppers.
The unit is very easy to handle, black lit LCD, erases trouble codes and determines the malfunction indicator lamp status.
It can also detect the OBD check and retrieve the freeze frame information.
The cable is detachable and replaceable.
Supports all 1996 and newer cars and light supplier trucks that are OBD2 compliant.
The Roadi RDT51 is a high-end handheld automotive diagnostic scan tool, specially designed for use by do-it-yourselfers who want/need a program that does a lot more than just learn trouble codes.
In addition to reading OBD-II DTCs, generated by virtually all new cars, brightness trucks and SUVs bought in the US from 1996 to the present, as very well as EOBD and JOBD codes generated by cars bought in Europe and Japan, the RDT51 displays code definitions on-screen, detects OBD-II freeze frame data and has memory/battery backup for off-vehicle data review and analysis."
Bought several years ago, tested, put away, and while never used on the road, it is fully functional.
Comes with carrying case, two separate cables, am informational mini CD, and manual.
$60 by Paypal, shipped USPS in the lower 48. I will be glad to answer any questions.
