Old 03-25-2016, 05:39 PM   #1
tandem54's Avatar
Roadmaster Sterling All Terrain Tow Bar with Guardian Rock Shield
Like New Roadmaster Sterling All Terrain Tow Bar with Guardian Rock Shield.
The Sterling All Terrain was designed, tested and manufactured to the highest standards. . .yours. And now, ROADMASTER's best tow bar is even better -- with non-binding All Terrain technology, you'll never struggle to release your tow bar again.
The Sterling All Terrain weighs just 35 pounds, yet pulls up to three tons. Steel and stainless steel at every critical point ensure superior strength and structural integrity.
The Sterling All Terrain is easy to connect, and its stainless steel inner arms telescope, center and automatically lock as you pull away. Once you've reached your destination, a unique storage lock secures the Sterling All Terrain in its stored position.
The Sterling All Terrain comes complete with safety cables and electrical wiring cord. Both are routed through center channel guides for added safety, convenience, and a clean, uncluttered appearance.
Beyond its many performance features, the Sterling All Terrain is aesthetically pleasing -- its anodized finish and sleek design complement your coach and your car. As well they should -- the Sterling All Terrain exemplifies ROADMASTER's highest standards, as well as yours.
There's no more binding with an All-Terrain Freedom Latch™
Releasing your towed car is easy with ROADMASTER's All Terrain Freedom Latch -- even when the tow bar is at a hard angle, or the towed car is out of level. The Sterling All Terrain's Freedom Latches disconnect first time, every time. No other tow bar makes towing this simple.
A unique eggshell design distributes pressure throughout the tow bar, making the Sterling All Terrain the world's strongest aluminum tow bar.
Aircraft-grade aluminum, anodized for maximum durability
Computer-designed and -tested for superior strength and styling
Exceeds all competitive products in stress and fatigue testing
Computer tested
ROADMASTER uses computerized testing on every new tow bar design. The program is called "FEA," which stands for "Finite Elemental Analysis." If that sounds complicated, that's because it is -- FEA is the same program NASA scientists use to test their new designs.
FEA transforms two-dimensional design drawings into three-dimensional objects, which can be rotated and studied on the screen as thousands of pounds of force are applied. Stress in the steel is pinpointed, and the design is manipulated to remove it.
ROADMASTER is the only towing products manufacturer to use computerized testing -- as well as "real world" physical testing -- to ensure structural integrity, longevity, and the safety of your family.
Non-binding aluminum tow bar with integrated safety cables and 4 wire electrical connection, stows on the rear of your motor home when not connected to your towed vehicle.
The Sterling All Terrain was designed, tested and manufactured to the highest standards, yours. And now, ROAD MASTERS best tow bar is even better with non-binding All Terrain technology, you'll never struggle to release your tow bar again.
The Sterling All Terrain weighs just 35 pounds, yet pulls up to three tons. Steel and stainless steel at every critical point ensure superior strength and structural integrity. The Sterling All Terrain is easy to connect, and its stainless steel inner arms telescope, center and automatically lock as you pull away. Once you've reached your destination, a unique storage lock secures the Sterling All Terrain in its stored position.
The Sterling All Terrain comes complete with safety cables and electrical wiring cord. Both are routed through center channel guides for added safety, convenience, and a clean, uncluttered appearance. Beyond its many performance features, the Sterling All Terrain is aesthetically pleasing its anodized finish and sleek design complement your coach and your car. As well they should the Sterling All Terrain exemplifies ROAD MASTERS highest standards, as well as yours.
Like New Roadmaster Tow Bar -- 4000-40
With its unique, egg-shaped design, non-binding Freedom Latch technology and lightweight aluminum construction, this feature-rich model might just be the best tow bar ever. It is safe, reliable and easy to use - you can't go wrong with Sterling.
Features:
• Tow bar allows you to safely and effectively tow your vehicle behind your RV
• All-terrain model features Freedom Latch for quick and easy disconnect in any environment
• Quick-disconnect system lets you quickly and easily mount and remove tow bar on your own
• Stainless steel inner arms telescope for simple hook up and automatically center and lock as you drive ahead, preventing sway and making hook up quick and easy
• Storage Latch allows the tow bar to automatically lock in place when folded toward your motor home, providing effortless and secure storage
• Aluminum construction is durable and lightweight
o Eggshell design distributes stress evenly for maximum strength
o Anodized finish adds durability to a sleek look
• Steel and stainless steel are built in at critical points to maintain structural integrity and smooth operations
• Heavy-duty, stainless steel EZ Hook safety cables are fast and easy to connect
• Cables and 4-pole wiring included are routed through a built-in channel to prevent dragging or tangling and provide a clean look
• Made in the USA
Specs:
• Capacity: 6,000 lbs.
• Wiring: 4-pole connector(attached) and 7-wire connector
• Weight: 35 lbs.
• Compatibility: works with all Roadmaster vehicle-specific base plates - EZ, MX, XL and Standard
Roadmaster 4000-10 Stowaway with Guardian Storage, Black.
The STOWAWAY (#4000-10) slides over your tow bars stinger or ball mount and converts the rear of your motorhome into a storage area for your Guardian rock shield. A center cut out allows quick and easy access to most motorhome electronics.
Stowaway mounts on your tow bar to store the Guardian quickly and easily. It slides over the 2'' shaft of your ball mount or tow bar, and secures with a set screw. Drop the Guardian onto the Stowaway and secure with pins for convenient storage. Saves storage space in your trunk or cargo bay! Powder coat finish resists corrosion. Sells for over $2500.00 new
Located in Surprise Arizona, will deliver within 50 miles.
$1500.00 O.B.O. takes it all home!
ID:	102828   Click image for larger version
ID:	102829   Click image for larger version
Forest River Lexington Grand Touring.
tandem54 is offline
Old 04-05-2016, 06:51 PM   #2
tandem54's Avatar
I'll deliver within 50 miles, but if you are farther we can figure something out.
tandem54 is offline
sterling
