Old 03-11-2015, 12:29 AM   #1
SeaHarley's Avatar
[SOLD] 2012 LaCrosse 308RES, Luxury Lite, TT
We would like to upgrade and have a beautiful, almost new, TT for sale:
2012 Prime Time LaCrosse, Luxury Lite, 308RES (Rear Entertainment Slide) Top of the Line by Forrest River in Excellent Condition. Only 2 1/2 years new! This Travel Trailer is 35' Long and 8' Wide with a dry empty weight of 7480 lbs. and max. of 9760 lbs. Recently had full maintenance and detailed.
The NADA Average Retail is currently $28,450 without listing any options. We are pricing this for a quick sale at $19,900.
Interested? Send me a PM.
We are in the North Baltimore Maryland area.
Thanks,
Lee.
Detailed Specifications:
2012 Prime Time Lacrosse Interior Standards:
• Solid Hartford Cherry Cabinet Doors
• Solid Wood Core Cabinets
• Predrilled and Screwed Cherry Finish Cabinetry
• Ball Bearing Full Extension Drawer Glides
• Video Pro Separate Cable Satellite Prep (UDC)
• Upgraded Residential Carpet with Pad
• EZ Command Center
• Night Shades
• Deep Overhead Cabinets in Slide Out
• Spice Rack
• Swivel Chairs
• Decorative Wall Light in Slide Out
• Deep Kitchen Pantry with Removable Shelves
• Large Panoramic Slide Room Windows
• ARMSTRONG Tough Guard Premium Vinyl Flooring
• *Fully Glued Application
• Oversized MAX Living Room Slide Out
• Floor to Ceiling Height = 78", (6' 6")
• Decorative Overhead Lighting Above Entertainment Center
• EZ Winterization Hookup
2012 Prime Time Lacrosse Exterior Standards:
• One Touch Electric Awning
• One Touch Electric Jacks
• Aluminum Wheels
• Universal Docking Station
• Outside Shower with Detachable Hose (UDC)
• Slam Latch Baggage Doors
• Aerodynamic Front Fiberglass Cap
• Front Diamond Plate
• 30 Radius Entry Door
• Folding Grab Handle
• Black Tank Flush
• Radius Triple Entry Steps
• EZ Tow Wide Track Suspension
• Radial Tires
• Super Lube Greasable Axle Hubs
• 30# LP Bottles with Easy Access Cover
• Quick Connect Exterior LP Connection
• Marine Grade Outside Speakers
• Black Framed Dark Tinted Radius Safety Glass Windows
• 30 AMP Power Chord
• Extended Drip Spouts
• Hitch Light
• TV Antenna
• Easy Access Low Point Drain Valves
2012 Prime Time Lacrosse Appliances:
• 26 LCD TV with Bracket to Remove
• 42 LCD TV on Power TV Lift
• Outside TV Bracket and Hookups
• AM FM CD DVD Stereo with iPod Hookup
• 3-Burner Range with Large Oven
• Range Hood w Light and Exhaust
• Large Double Door Refrigerator
• 13500 BTU Air Conditioner
• 30000 BTU Hi Capacity Gas Furnace
• 6 Gallon Gas / Electric Water Heater with DSI
• 18 Gal. Hr. Quick Recovery Mode for Water Heater
• Water Heater Bypass
• Hi Capacity Water Pump
2012 Prime Time Lacrosse Construction:
• Gel Coated Fiberglass Exterior
• ETERNABOND Solid Construction
• *Laminated Aluminum Framed Side Walls and End Walls (R-11)
• *Laminated Aluminum Main Floor (R-14)
• *Laminated Slide Room Walls and Roof (R-11)
• Thermal Package Plus
• *Enclosed and Heated Underbelly
• *Heated Holding Tanks
• *Enclosed and Heated Dump Valves
• One-Piece Rubber Roof
• Snow Load Approved 5 Truss Rafters w Double Insulation (R-14)
• 38 WALK ON Roof Decking
• Upgraded Oetiker Water Line Fittings
2012 Prime Time Lacrosse Kitchen:
• Solid Surface Countertops
• Deep Double Bowl Undermount Kitchen Sink
• Sink Cover Storage Area
• Hi Rise Metal Kitchen Faucet
• Oil Rubbed Bronze Fixtures & Hardware
• Residential Style Microwave
• Dinette Table
• MAX STORAGE Oversized Pots N Pans Drawer
• Trash Can Storage
2012 Prime Time Lacrosse Bathroom:
• ABS Tub Shower Surround
• Skylight Over Tub Shower
• Glass Shower Door
• Porcelain Toilet with Foot Flush
• Power Vent Fan
• Wooden Medicine Cabinet with Mirror
• Large Bathroom Sink
2012 Prime Time Lacrosse Bedroom:
• Solid Pocket Doors
• Ceiling Mounted TV Bracket
• Dual Wardrobes
• Under bed Storage with Struts
• Quilted Residential Bedspread
• Bedroom Heat and AC Vents
• Evergreen Select Foam Mattress
2012 Prime Time Lacrosse Options:
• Free-Standing Table with 4 Chairs
2012 Prime Time Lacrosse Safety Equipment:
• CO Detector
• LP Detector
• Fire Extinguisher
• Propane Alarm
• Smoke Alarm
• Dual Hitch Safety Chains
ID:	71144   Click image for larger version
Name:	2015-02-07 13.22.41.jpg
ID:	71145   Click image for larger version
Name:	2015-02-09 13.24.35.jpg
ID:	71146   Click image for larger version
Name:	2015-02-13 15.13.57.jpg
ID:	71147   Click image for larger version
Name:	2015-02-16 10.14.41.jpg
2012 Lacrosse, 308RES.
2013 Ford F150, XLT, 4x4, Supercrew, Eco-Boost.
Lee, Dawn and "CoCo", the dog!
2015 Overnight Camping Days = 25, States Below:
SeaHarley is offline
Old 03-11-2015, 11:55 AM   #2
SeaHarley's Avatar
Instead of a Dinette Booth, there is a Dinette Table with 4 Chairs.
I modified the table so it would rotate, giving more room inside when slides are closed. I also installed a locking system to lock in place while traveling and eliminating any table wobble .
Additional items:
Keyed Battery Cut-Off, Switch.
Digital 12 Volt Battery Meter.
Additional Battery Box, for a second battery if desired.
Water Heater Tank, Drain Valve.
Battery powered Tongue Jack.
Many other additions.
Name:	2015-02-09 13.25.59.jpg
ID:	71153   Click image for larger version
Name:	2015-02-09 13.25.25.jpg
ID:	71154   Click image for larger version
Name:	2015-02-09 13.29.47.jpg
ID:	71155   Click image for larger version
Name:	2015-02-13 15.11.17.jpg
ID:	71156   Click image for larger version
Name:	2015-02-09 13.27.07.jpg
Old 04-21-2015, 04:09 AM   #3
SeaHarley's Avatar
This TT has been sold, how do I get it changed and marked as sold?
Thanks,
Lee
Old 04-21-2015, 05:49 AM   #4
I believe you have to ask the moderator to put sold on it.
gatnfans is offline
Old 04-21-2015, 04:31 PM   #5
Terier's Avatar
Congrats on the sale! I will add the "Sold sign" to the title.
Terier is offline
2012, lacrosse, prime time
