Old 07-12-2017, 01:16 PM   #1
Jimsue's Avatar
[SOLD] - Demco Hijacker 18k Autoslide
Demco RV Fifth Wheel - DM8550022- Make Offer
Used one season
This hitch slides automatically as you drive to give you 14" of additional clearance for tight turns. A wraparound jaw provides a smooth ride and a locking bar offers added security. Hitch removes easily for full bed access.
Features:
5th-Wheel hitch mounts in your short-bed truck bed so you can tow your 5th-wheel trailer
Automatic slider provides clearance required for your short-bed pickup to turn safely at slow speeds
No more getting into and out of the truck to operate a manual slider
Head slides toward the tailgate when you turn and back toward the cab when you straighten out
Rack-and-pinion gears create smooth, controlled, automatic motion
Rotating hitch head turns up to 90 degrees with your trailer
Rotation creates the force that propels the automatic slider
Built-in brackets stabilize your pin box so the king pin won't rotate in the hitch - no need for a separate capture plate for standard pin boxes
Rail-free design allows for full access to truck bed when hitch is removed
Wraparound, single-piece jaw provides a secure connection
360-Degree jaw-to-king-pin contact
Less rattle and more security than slide-bar jaws
3/4" Thick, solid steel locking bar reinforces the connection of your coupled trailer
Automatically locks into place when the jaw closes
Double-pivot hitch head eases hookup and helps to limit chucking
Pivots front to back and side to side
3 Height settings to fit your application
Cushioning polyurethane dampeners help reduce noise and absorb road shock
Spring-loaded handle with comfort grip allows for simple coupling
Tethered safety pin lets you secure the handle in the open or the closed position
Sturdy steel construction with rust-resistant black powder coat finish
Custom underbed mounting kit (sold separately) required for installation
Made in the USA
Specs:
Designed for use on 6-1/2' truck beds
Fits standard pin boxes 12" - 14" wide
Locking plates (sold separately) are required for use with Glide Ride, Mor Ryde, Trailair Tri Glide, and 5th Airborne pin boxes
Gross towing weight: 18,000 lbs
Vertical load limit: 4,500 lbs
Travel: 14" front to back
Hitch height settings: 15-1/2", 16-3/4", and 18-1/4"
5-Year limited warranty
Notes:
i will deliver to most locations in SE or Grand Rapids area of Michigan.
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
andersen ultimate 5th wheel hitch
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline
Old 07-28-2017, 08:36 PM   #2
Jimsue's Avatar
Also viewable at DH Day Campground
Currently in Sleeping Bear Dunes National Shoreline area until Labor Day ( Traverse City Area)
2013 Sabre BKOK 31
Jimsue is offline
Old 01-12-2018, 08:45 PM   #3
Jimsue's Avatar
Sold 1/12/18
2013 Sabre BKOK 31
Jimsue is offline
Old 01-12-2018, 09:08 PM   #4
Mr. Dan's Avatar
Originally Posted by Jimsue View Post
Sold 1/12/18
Thanks for the update.
Marking SOLD.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Mr. Dan is online now
slide
