Old 11-09-2016, 05:29 PM   #1
Texag98's Avatar
(SOLD)Equalizer weight distribution hitch for sale
I have a 12000 lbs equalizer weight distribution/sway control hitch for travel trailers or heavy equipment. I paid $550 and used it 6 times. Still looks new. No rust never left outside. Asking $399 Fort Worth Texas
Features:
+Evenly distributes weight over axles of tow vehicle and trailer for stability and control
+Creates a more level ride for both tow vehicle and trailer
+Integrated 4-Point Sway Control limits side-to-side movement of trailer
+Brackets keep spring bars in place for a rigid system that holds trailer in line
+No lift chains - spring bars can't move freely
+Steel-on-steel friction helps to minimize sway caused by winds, curvy roads or sudden maneuvers
+Unique design makes system compatible with surge-type brake actuators
+Spring bars flex appropriately over uneven terrain for a controlled, even ride without the bounce
+Constructed of chromoly steel for superior dexterity and spring
+No-drill, clamp-on brackets can be adjusted along the trailer frame to accommodate frame- mounted items such as gas tanks, toolboxes or generators
+Desired tilt is achieved with traditional washer design
+Add or remove washers from spacer rivet to tilt head up or down
+Dipped steel construction is durable and corrosion resistant
+Snap-up lever eases installation by reducing lifting required by trailer jack
+System includes head assembly, adjustable shank, spring bars, sway control brackets, hitch ball, lift handle, pin and clip, and all necessary hardware
Name:	ImageUploadedByForest River Forums1478730453.508014.jpg
Texag98 is offline
Old 11-18-2016, 06:18 PM   #2
Texag98's Avatar
Bump
Texag98 is offline
Old 11-21-2016, 06:28 PM   #3
Is the shank a 2" or 2.5"?
Marc Haught
15 Vengeance 31V
15 Ram 2500 6.4
MarcH is offline
Old 11-21-2016, 06:32 PM   #4
Texag98's Avatar
It is a 2" shank. You can use a sleeve to make it 2.5" also if needed.
Texag98 is offline
Old 01-22-2017, 07:13 PM   #5
Texag98's Avatar
Sold
Texag98 is offline
equalizer, for sale, hitch, weight, weight distribution hitch
