Old 09-25-2017, 08:08 AM   #1
Playtime III
Playtime III's Avatar
[SOLD] - Master Tow Dolly
Located in Holiday, FL (NW burb of Tampa)
-Master Tow 80TSB-14
-Max towed vehicle weight: 4900lbs
-Max towed vehicle tire tread width: 80”
-Tilt bed for easy loading
-Pivoting wheel pan (no need to leave towed car steering unlocked/key on)
-Custom wiring looms (No cheap crimp connections to fail/corrode)
-Polyethylene fenders (won’t rust)
-ST205/75D14 Tires
-Dolly weight: 550lbs
Added Options/Upgrades:
-Hydraulic surge drum brakes. Low profile coupler allows use of dual receiver to also carry bikes/cargo trays while towing car. No brake controller required in towing vehicle.
-LED tail/marker lighting (marker lights mimic tail lights so you can see brake/turn are on from your mirrors)
-Ring Adjustable wheel straps (fits rims 12-20”). Filthy but no tears/wear.
-Spare tire (ST205/75D14)
-Spare tire mount kit (not installed to reduce tongue weight when moving around empty)
-Towed vehicle security chains (back up to the straps holding car to dolly)
Requirements:
-Class III (5K) receiver or better (for max towing rating)
-2” ball with 5k rating
-4-pin flat trailer electrical connector
-Hitch Ball height should be between 18” and 20” for maximum ramp/ground and car/dolly clearances.
-No title/registration/plate in Florida, possibly other states
Price $1,000
Playtime III
TT 2011 2902SS
TV 2007 F-150 SC 4x4 5.4
800 wd/dual cam sc
Playtime III is offline
Old 09-25-2017, 09:22 AM   #2
Playtime III
Some pix...
ID:	152465   Click image for larger version
ID:	152466   Click image for larger version
ID:	152467   Click image for larger version
Playtime III
TT 2011 2902SS
800 wd/dual cam sc
Old 09-25-2017, 04:30 PM   #3
Playtime III
SOLD
Playtime III
TT 2011 2902SS
800 wd/dual cam sc
Old 09-26-2017, 08:06 AM   #4
Mr. Dan's Avatar
Originally Posted by Playtime III View Post
SOLD
Item is SOLD
SOLD.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Mr. Dan is offline
