Old 03-21-2015, 07:57 AM   #1
[SOLD] PULLRITE SUPERGLIDE #4100 16k
Autoslide 4 shortbed trucks. Used 3 yrs. Good condition. I have mounting bars and pins but you will need the truck specific frame brackets for your truck if you want the under bed mounting system. I also have a capture plate for a lippert 1621hd pin box. If you have industry standard rails in your bed i have an adapter kit #4409 (new) in box.
$750.00 takes it all JOHN
ID:	71808   Click image for larger version
ID:	71809   Click image for larger version
ID:	71810   Click image for larger version
ID:	71811   Click image for larger version
jkweller is offline
Old 03-26-2015, 10:52 AM   #2
hitch
What kind of truck did hitch come out of?
Thanks,John
jobren4 is offline
Old 03-26-2015, 11:03 AM   #3
Herk7769's Avatar
Thanks,John
It should not matter as the only things that change from truck to truck are the frame mounts that were not included.
http://www.pullrite.com/products/tra...-mounting-kits
The super rails are adjustable and the hitch is universal.
Here is a photo of the "used" one I bought on eBay. The plates to the right are what make the install unique to the truck (my 2008 GMC Sierra 2500HD).
Name:	Includes Mounting plates.jpg
File Type: pdf 4100-4400 14k-18k SG Installation Instructions 12-28-06.pdf (1.39 MB, 32 views)
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Herk7769 is offline
Old 03-26-2015, 11:57 AM   #4
I had it mounted in a 2007 RAM 2500. Herk7769 pretty much summed it up, the only things I don't have are the truck specific frame mounts. You would need those or if you have industry standard rails in the bed of your truck, with the #4409 adapter kit that goes with it , it would mount right up.
jkweller is offline
Old 04-12-2015, 08:06 AM   #5
Hitch has been SOLD
Thanks FROG Community. Hitch has been SOLD
jkweller is offline
Old 04-12-2015, 07:33 PM   #6
1surveyor's Avatar
Congrats i have been trying to sell one for a year now
1 Surveyor
2015 Silverado Duramax w/Allison transmission
2014 surveyor 293RL fifth wheel
1surveyor is offline
pullrite, superglide
