Old 10-11-2016, 05:55 PM   #1
tandem54's Avatar
[SOLD] - Roadmaster Sterling All Terrain Tow Bar with Guardian Rock Shield
Like New Roadmaster Sterling All Terrain Tow Bar with Guardian Rock Shield.
Comes complete with safety cables and electrical wiring cord.
Features:
• Features Freedom Latch for quick and easy disconnect.
• Quick-disconnect system lets you quickly and easily mount and remove tow bar.
• Inner arms telescope for simple hook up and automatically center and lock as you drive ahead, preventing sway and making hook up quick and easy
• Storage Latch allows the tow bar to automatically lock in place when folded toward your motor home, providing effortless and secure storage
• Aluminum construction is durable and lightweight
• Anodized finish adds durability to a sleek look
• Steel and stainless steel are built in at critical points to maintain structural integrity and smooth operations
• Heavy-duty, EZ Hook safety cables are fast and easy to connect
• Cables and 4-pole wiring included are routed through a built-in channel to prevent dragging or tangling and provide a clean look
• Made in the USA
• Capacity: 6,000 lbs.
• Wiring: 4-pole connector(attached) and 7-wire connector
• Weight: 35 lbs.
• Compatibility: works with all Roadmaster vehicle-specific base plates - EZ, MX, XL and Standard
The Roadmaster Stowaway mounts on your tow bar to store the Guardian quickly and easily. It slides over the 2'' shaft of your ball mount or tow bar, and secures with a set screw. Drop the Guardian onto the Stowaway and secure with pins for convenient storage. Saves storage space in your trunk or cargo bay! Powder coat finish resists corrosion.
Sells for over $2500.00 new
Located in Surprise Arizona, will deliver within 50 miles, if farther we can figure something out.
$1200.00 O.B.O. takes it all home!
ID:	122735   Click image for larger version
ID:	122736   Click image for larger version
Forest River Lexington Grand Touring.
tandem54 is offline
Old 11-03-2016, 12:01 PM   #2
tandem54's Avatar
Reduced price
I'm REDUCING the price to: $900.00 or best offer, I just want it out of my garage. I don't have a "Toad" so I don't need it. Thanks
tandem54 is offline
Old 11-15-2016, 02:27 PM   #3
tandem54's Avatar
Sold!! Sold!! Sold!! Sold!!
sold!! Thank you for the listing.
tandem54 is offline
Old 11-15-2016, 04:55 PM   #4
Mr. Dan's Avatar
Marked SOLD per OP.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 49
Mr. Dan is online now
sterling
