Old 05-31-2016, 09:55 PM   #1
frozen's Avatar
Torflex trailer axles
Two Dexter Torflex trailer axles, torsion suspension with E-Z Lube bearing lubrication. 4000 lb. capacity each. 10" electric brakes, 5-bolt hubs for 15" rims. 22 degree arm angle. Axles, brakes, bearings in good condition. These axles were removed from my Rockwood 5th wheel so "taller" axles with 45 degree arm angle could be installed. $250 / pair. Located in northern Minnesota.
ID:	109743   Click image for larger version
ID:	109744   Click image for larger version
ID:	109745   Click image for larger version
frozen is offline
axle, trailer
