Old 02-25-2013, 04:05 PM   #1
LKicklight's Avatar
Want to Buy
Need a Fifth Wheel King Pin Support for out Crusader 270RET...Understand that when used, it takes some of the bounce out of the unit when set up...Found one here new at our local dealership, thought I would ask here first before spending the bucks..I'm cheap you see..
LKicklight is offline
Old 02-25-2013, 07:52 PM   #2
Freds342's Avatar
I have a Bi-pod kingpin stabilizer that you can have for packing and shipping.
PM me. I'm in California, so you might be able to buy one locally for what it would cost to ship.
Weighs about 20-lb.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline
Old 02-25-2013, 08:56 PM   #3
PapaSmurf's Avatar
You would do better with a jack stabilizer system like JT Strongarm. They attach from the base of the jacks up to the frame. Once you are level, you tighten the bolts and enjoy a rock solid camper. It does not stop all movement, but it is very close. The wife and I do not disturb each other getting up for our nightly trips to the potty. Before the JT Strongarm system we rocked all night...
2011 Ram Truck 2500, Crew Cab, 6.7L CTD, 4X4, 3.73 Rear
PapaSmurf is offline
Old 02-25-2013, 09:04 PM   #4
TURBS's Avatar
I believe he is talking about bouncing not rocking .... kicker correct me if I am wrong.
Stabilizer systems will prevent rocking back and forth and side to side but not up and down .
Bouncing is from tire flex and or leaf spring and or torsion give which can only be prevented by jacking up unit and placing jack stands under frame rails.
turbs
TURBS is offline
Old 02-25-2013, 09:29 PM   #5
Freds342's Avatar
We had two different Wildwoods, a 26SS and a 32DS, and never used any of those.
The 32DS came with the Bi-pod, and it is just setting in my back 40.
....and I LIKE 'rockin!
Freds342 is offline
Old 03-21-2013, 11:08 AM   #6
LKicklight's Avatar
Still would like to locate one of these to try...just PM and let me know where you are and how much..
Thanks,
Dallas, GA
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
Old 03-21-2013, 11:09 AM   #7
TURBS's Avatar
Kicker I'd remove your number from the open forum and pm it to the oc.
Less then nice people will like your number for spam and other crap.
TURBS is offline
