Old 05-22-2010, 08:12 PM   #1
NWC72's Avatar
Wheel Chocks for sale
EASY CHOCK WHEEL LOCKS
(formerly “Chatham Chocks”***)
What makes Easy Chock Wheel Locks any better than a commercially made product?
#1. Value! You can spend almost twice as much for a mass produced chock that does the same thing, and probably not as easily. Most everyone who’s seen them has wanted a pair for themselves. Why spend $100 for when you can do it for about half that amount?
#2. Ease of use! Once you set the Easy Chock Wheel Locks for the first time, you won't need a wrench, rod, wing-nut, or some type of crank to install them ever again. You simply set them in place, flip the lever, and your wheels are locked. Easy to put on and easy to remove. Takes just seconds to place them. No misplaced wrenches, lost or dropped lock nuts, constant adjusting, etc.
#3. Strength! This design gives you four points of contact on your tires, two high and two low. The physics of this design allows your tires to work against one another giving a SOLID lock up on any surface or incline. Fifth wheelers—set your Easy Chock Wheel Locks and your trailer will not budge as you hook up or unhook.
#4. Durability! Easy Chock Wheel Locks are made from all new materials; the blocks themselves are pressure treated 4 x 4 pine. With minimal care they will easily outlast your RV. No stripped plastic threads, worn pressure plates, etc.
You probably spent a LOT of money getting the trailer that was 'just right' for your needs. Why settle for a mass produced universal product to stabilize it?
Our quality wheel chocks are monitored from layout to finish. This insures your satisfaction and a good fit!
I will GUARANTEE that Easy Chock Wheel Locks will fit your rig. You will simply email me the HEIGHT of your tires and the SPACE between your tires at the closest point, and your chocks will be custom made to fit your trailer.
Cost is $54.95 and the shipping is FREE.
To order a set, go to Ebay Motors and search "RV Chocks".
Of course, when you buy from us you get a complete set
that takes care of BOTH sides of your trailer.
Thanks for looking!
(Tell your friends!)
See how easy these chocks work at:
(Special thanks to K. B.!)
***The “Chatham Chocks” maker is no longer in business
2005 Rockwood 8280ss
2003 GMC 1500 Extended Cab "Dwight" (sold)
2005 Dodge Ram 2500HD QC4x4 Cummins "Brutus"
Drawtite Brake Controller
16K Pullrite Superglide
NWC72 is offline
