Old 06-06-2016, 08:14 AM   #1
checca's Avatar
Thumbs up Winegard Carryout Portable Automatic Satellite Antenna Direct TV / Dish RV Camper with
Winegard Carryout Portable Automatic Satellite Antenna Direct TV / Dish RV Camper with stand.
All cables needed for Direct TV.
120v to 12v power supply
Used two camping seasons.
The Winegard Carryout automatic portable satellite dish is a true fully automatic satellite antenna. Simply turn on the Carryout and it will automatically find the satellites for you. No remote, no controls... just turn it on!
Line of site problems in your favorite RV camping spot? With the Winegard Carryout you can pick your camping site first and always have the peace of mind that you will get signal too! With 50' of cable included, you will have a 50' diameter circle to locate your signal. This should be a sufficient range to find a good signal unless you are deep woods camping. At that point the only way to get a good signal no matter how much cable you have might be to climb and perch in a tree.
Compatible with both DISH Network, DIRECTV and Bell TV. Works with most receivers that can get SD programing:
http://www.winegard.com/kbase/uploads/2452172.pdf
ID:	110266   Click image for larger version
ID:	110267   Click image for larger version
ID:	110268   Click image for larger version
ID:	110269   Click image for larger version
2013 Lacrosse 318bhs
2010 Toyota Tundra Crew max 5.7 flex fuel / Installed airlift ultimate 5000 air bags and smart lift automatic leveling system.
Yamaha EF2000iS 2000 Watt Inverter Generators
Minooka, IL.
checca is offline
Old 06-06-2016, 10:28 AM   #2
checca's Avatar
Lightbulb
Asking $300.00 ... Pickup in Minooka, IL (60 miles southwest of Chicago) ... Please PM me.
Minooka, IL.
checca is offline
Old 06-06-2016, 08:21 PM   #3
Rmk2001800's Avatar
Sent pm
Rmk2001800 is offline
Old 06-08-2016, 07:25 AM   #4
checca's Avatar
SOLD
SOLD
Minooka, IL.
checca is offline
Old 06-08-2016, 07:34 AM   #5
What is the price? Will you ship , thanks.
Dh5653 is offline
antenna, camper, satellite, winegard
