08-03-2011, 06:33 PM
Black tank warranty
We are interested to know if anyone else has been told by their RV dealer that the manufacturer will void the warranty on their black system if they are being pumped out by any kind of a pumping system such as a "honey wagon"?
08-03-2011, 06:40 PM
Makes sense to me, as I wouldn't warranty it either if I were them.
I would bet that most people would be too dense to open the toilet valve when having their tank pumped out.
01-17-2012, 10:45 PM
Wouldn't the stack pipe pull air in from the top?
01-17-2012, 11:11 PM
Moderator
What kind of warranty is on a black tank? Either it holds stuff, or it doesn't. Who can say or prove it was damaged by having it pumped? If it is a Forrest River product, it is covered for 12 months, after date of purchase. Now the real question, was the dealer trying to sell you a blue boy sewer tote, or something similar?
And what about the gray system? If you are having your trailer pumped, wouldn't you want to pump both? The gray fills much faster than the black.
The other thought that comes to mind, in defense of the dealer, if you neglect the black system, and have to have it cleaned and pumped, then maybe yes, would void warranty.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
01-18-2012, 06:03 AM
Lou Amadio
If they use a power pump to suck the liquids out and it has a clogged vent; you could easily collapse the tanks (black or gray). I would think you would need a "double failure" to damage your system if the "Honey Wagon" was correctly sized for the job.
Or perhaps they worry that "Bubba's" homemade "Honey Wagon" system has an 8 million horse power pump and just turning it on will collapse the tanks.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
01-18-2012, 10:44 PM
If the stack pipe was clogged, no one would want to flush the toilet and the owner would take to a RV shop to get it fixed. Second, would a campground want to take the liability on an over powered pump damaging someone else's rig and dumping poo on their site? I have never had to sign a waver to get a honey wagon to pump my rig out, so I wouldn't be responsible for an imploded black tank.
01-18-2012, 11:34 PM
Moderator
OK, I made some ASSumptions. New owner, joined in August, but first post now in January.
Now, as a tech, when you get a new camper, you have one year warranty, standard. This is assuming you do the required maintenance, like dumping the tanks, and caulking the roof if needed. You are also required to get problems back to the dealer, at your expense. Even if the dealer took it and parked it for you, it is your responsibility to get it back for problems.
Now the original post, "pumped out by a honey wagon". Why pump what camper sewer systems deliver by gravity? The few campgrounds we stayed at that offered sewer service, brought a blue tote, gravity filled the tote, the took it to the honey wagon to be emptied. There may be more to this story than we see.
Windrider,
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
01-19-2012, 10:31 PM
Lou Amadio
I had a free "pump out" with a 5 day stay and they used a pumped system towed by their tractor. They had to lift the black water up and into their tank. Gravity did fill the hose, but the pump was needed to get it up and into the tank and then they pumped the gray water afterwards.
They seemed to have no problems and the tanks still work just fine.
01-20-2012, 07:32 AM
interesting...has anyone actually had a tank collapse?
if the pull was severe enough to damage the tank, i would think u could tell.
01-20-2012, 01:42 PM
A number of years ago, while leaving a NA$CAR track, they had a line of honey wagons pumping the RV's as they left. Many of these were the vacuum trucks, designed to lift sewage through a 3" or 4" suction tube, 15-20' (designed for cleaning manholes). The guy runnig the truck had me go inside and open the flap on the toillet while he pumped, so that air could enter there, as well as from the vent.
That kind of strong suction, with a typical RV having only a 1.25" or 1.5" vent could easily cause a problem with the tank, and if the vent is at all clogged (with "stuff" or by mud wasps) it could very conceivably cause a collapse of the tank.
From that track, we went on to a coastal CG that had a tractor drawn honey wagon and used a 12v macerator pump. Those pumps create very little (if any) suction, and are completely dependant upon gravity to get the effluent from the tank to the intake side of the pump.
Be safe, and Everyone Goes Home!
Fire Instructor
2004 RAM 1500 4x4 Quad Cab w/Hemi, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 237 |
| 13 members and 224 guests |
| BigDogD, cardinal4fun, dangerranger363, hotrodj125, Leathergypsy, mblanks2, mrthumper24, navypoppop, nrcamp, papap, stevo, Unruly, Vernk |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
