07-07-2016, 08:34 AM
Originally Posted by Brewhedd
We have been dedicated Flojet users for many years now.
I couldn't be bothered to tap into 12V near the drain so I made an extension with a Bargman socket on it.
A few tips, if I may...
- Always, always, ALWAYS test your Flojet to be sure it's operating BEFORE you open any drain valves. A momentary tap of the button is enough.
- The flush port valve is one-way. MOSTLY. Do not use a potable water hose as a flush hose and if your flushing hose is not connected FOR THE LOVE OF GOD CLOSE THE FLUSH TAP.
- A clear elbow will allow you to see how clean your drain water is and will enlighten you as to what passes through a digestive system intact. Disgusting? Perhaps. Fascinating? Definitely.
- The flush port will not spray the inside of your tanks, but it will allow you to back fill the tanks which will help clean them.
- DO NOT GET DISTRACTED WHILE YOU ARE BACK FILLING YOUR WASTE TANKS.
- If your black tank does not have a built in rinser it will benefit from the periodic use of a tank wand.
- When you are flushing the drain hose with the flush port, be sure the Flojet is running if the valves are closed, or the pressure will cause the the water to leak out the valves. THIS CANNOT BE GOOD FOR THE VALVES.
- After flushing the drain hose if you cannot pump all of the clear water out of the Flojet down, disconnect the flush hose and open the tap to let air into the system.
- Unless you need a shower, shut off the flush hose and open the flush tap on the Flojet to depressurize the flush hose BEFORE you disconnect it from the Flojet
- Don't be surprised if someone refers to your Flojet as a poop cannon.
- Take your time, use plenty of flushing water and relax knowing that you avoided the dump line at the RV park. Enjoy an adult beverage when you're done. But wash your hands first.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
07-07-2016, 10:05 AM
Always Learning
My thinking for this is using a FloJet to pump "stuff" into a portable tank in my truck bed. Save me the hassle of towing a portable tote.
Any chance this'll work? Or major concerns about it?
07-07-2016, 10:15 AM
That is how I use mine and it works very well with no problems. By the way I got mine on ebay for $155.00. Check there before you buy anywhere else.
2016 Vibe Extreme Lite 315BHK
2006 F150 Supercrew 4x4
07-07-2016, 10:37 AM
No problem. You'd just need a way to get it from the tank into the dump station drain (if the tank has bayonet fittings you could use the Flojet for that too). And you would want to keep a flush hose for rinsing out the Flojet and whatever drain hose you're using.
07-07-2016, 10:49 AM
Been using one for years, it's great!
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
07-07-2016, 10:57 AM
I just picked up the thetford sani con today.
Should work well!!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
07-07-2016, 11:18 AM
Always Learning
Thanks to both of you. My friend made some 150 gallon bladders with 3" bayonet fittings on it. I'm hoping to do the same thing and then it'll let me easily take care of my own stuff AND take it for some distance without driving at 1/2 the pace of a snail.
07-07-2016, 12:43 PM
My pleasure. Please do note my first tip above. I had a Flojet quit working once but I didn't notice until after I had opened the black tank valve. Luckily I had a bucket and a lot of clean water close at hand.
07-07-2016, 12:45 PM
Always Learning
My big concern with the Flojet is the propeller and my family's long hair. We are a bunch of wookies.
07-07-2016, 01:05 PM
Not a problem for me personally...
But my girls are a different story.
Luckily the impeller is easy to remove. Take off the clear elbow and the rubber plug at the bottom - the shaft extends outside the motor and can be held stationary with a large flat blade screwdriver.
The impeller is held in place with a nut and a tabbed washer - a ratchet, extension and socket (sorry, I don't remember the size) will remove the nut, allowing the impeller to come out for cleaning.
07-07-2016, 01:36 PM
Always Learning
Have you had an issue with it clogging/jamming up with hair while dumping? Or is cleaning it just a little preventative maintenance that you do + it takes care of it?
07-07-2016, 02:18 PM
Yes to the latter. I don't have to clean it after every use - just a couple of times a season. Wookiee fulltimer mileage may vary.
07-07-2016, 02:33 PM
Always Learning
Ha! Fortunately we wouldn't use it all that often- we are mostly RV park queens.
Thanks greatly for answering my questions and thanks to Brewhedd for posting the topic.
07-08-2016, 08:00 AM
That's a good price. I checked Ebay and a few other sites before I purchased and the link I posted was the best price.
