Garmin RV with camera
Last summer I purchased the Garmin RV760 and ordered the camera as well. I tested the camera on my Rockwood 8289 but never mounted it. Right away I found that I would need the extension cable offered from Garmin for this camera. By the time I got the camera and the cable the fifth wheel was covered and forgotten for the winter.
I recently traded the Rockwood for a Wildcat and finally got around to mounting the camera.
All worked pretty well as far as viewing through the Garmin but I was pretty unhappy with the picture quality. Lighting is a huge issue and shadows really mess up the view. My previous RV was a class A that had a factory backup system. The difference in the camera was ridiculous.
I talked to the people at Wildcat and oredered the Voyager that is designed to hook up to the Wildcat. I will see if there is an improvement and let you know.
I marked this with a negative because I was not happy with it. In all fairness it did what it was designed to do. It is far better than none at all.
Jim, Julie and Rags the boss.
2015 Dodge CTD 3500 Bighorn pulling 2014 Wildcat 317RL. Life is good when spent with family and friends.
