09-15-2016, 09:59 PM
RV Cable Grips (New Product)
While I was at the Goshen FROG Rally this year and I ran into a man named Jim Wright who had a great new idea for you to hookup you TV coax with little effort or tools. He designed this thing and started selling it at the Goshen FROG Rally this year and it’s called
“RV Cable Grip”.
How many times have you had to screw in your coax at a campground and found the cable plug in the most awkward location that it was nearly impossible connect without saying a few choice words. %&!? If you have big fingers or have arthritis in your fingers you will really like this.
Well, Jim had the same problem and designed the RV Cable Grip.
It easily installs on to your existing coax and gives you more gripping power to screw your TV coax in and no more looking for that little wrench whatever the size is. LOL
OK I said enough and wanted you to check out the RV Cable Grip.
Cable Grip Video #1 - https://youtu.be/DauSuzA_Wfw
Installing RV Cable Grip Video #2- https://youtu.be/VgRXjsq2x5s
Website - www.rvcablegrip.com
I am not associated with Jim and just talking about his great idea that you may find interesting and maybe use like I did. Yes I have them on my coax now.
Oh I forgot to mention Jim is a FROG member and will be at the "FROG-TOBERFEST"
Amana RV Park Amana, IA
September 29 - October 2, 2016
09-15-2016, 10:41 PM
Land of the Midnightsun
That's good idea
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
09-15-2016, 10:43 PM
Nice idea but YIKES! they come out to $10.00 a piece with shipping..
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
09-15-2016, 11:40 PM
Radio Shack ~~ a small piece you screw onto your cable then it just pushes into your RV and the post connection. $1.99 each. I have 3 different size cables and bought 6.
RadioShack Screw-on-to-Push-on Adapter $1.99
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
09-16-2016, 12:14 AM
I bought a few of these and they never seem to hold onto the treads at the campground. They were always loose even after I tried to tighten the wire ring.
09-16-2016, 12:19 AM
That is also what we have used for several years,works fine! Youroo!!
09-16-2016, 07:10 AM
They work great for me. I put them on all my cables.
09-16-2016, 07:55 AM
Not knocking the fella's idea.
*HERE* is a tool for $2.66 with FREE shipping.
It has a little 7/16" socket at the end that fits the coax connector.
These have been around the cable industry for years.
09-16-2016, 07:59 AM
X2
B and B
09-16-2016, 09:30 AM
Never seen these. Really cool but I would forget where I stored it when I need it.
09-16-2016, 12:13 PM
Canadian Member
For some reason, they don't ship to Canada!
09-16-2016, 01:50 PM
I picked up both the Cable Grip and the Coax Socket. I'll try them out. Thanks for the information!
FYI, the Radio Shack Idea was good, but they don't have them online and no more of those stores around here.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
09-16-2016, 01:53 PM
X2 Iggy: I also purchased (and Jim installed them on my 2 cables) and the work great in tight areas and with arthritic fingers!
09-16-2016, 02:09 PM
I ordered them online and the picture was taken from online yesterday. Mine arrived about 3-4 days after ordered.
09-16-2016, 02:11 PM
X2, I've used these in the past and they do slip on but in a lot of campgrounds not tight enough. Also with the weight of the cable pulling down they were not reliable enough for me. I took them off my cables.
09-16-2016, 02:35 PM
For those of y'all that have Comcast/XFINITY....the next time you get a visit from one of their techs ask them to replace the connectors on your cable. They'll put the big screw on ends on and won't charge you. I always get a courtesy wire inspection from them once a year and had them do the mod.
BIRDS AREN’T REAL
09-16-2016, 04:00 PM
Cable connectors
We have been using these for over 10 years with no problems. You can get them on Ebay cheaper than Radio Shack.
VMI'62
09-17-2016, 08:25 AM
Then do an eBay search for "push on cable connect adapter". 2 of them for less than $5.00 including shipping
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
09-17-2016, 08:37 AM
x3. Love this little tool.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
09-17-2016, 09:18 AM
x4 for the little tool. Have one at home and one in the 5th wheel.
2017 Berkshire XL 40A & 2017 Ford Focus SE
I Built and Fly - Van's Aircraft RV-12
Ham Radio - W9EAA
