Originally Posted by Melntb1
Does anyone have pictures of their install with regards to how the line enters their rv? My husband is very leery about making any more holes than necessary, especially the fiberglass roof. Thanks in advance!
If you pull the trim ring off your roof vents, many times you will find there are channels in the roof insulation for wires that might run over to a cabinet. You can run a wire thru the vent frame. Use a rubber grommet thru the metal frame so not to damage the wire.
Or, you can run the wire down thru the frig vent.
