08-23-2017, 06:39 AM
#21
Originally Posted by spierce617
That's a great price.
2013 Palomino Stampede 23S HTT
2015 Dodge Ram 1500 6" lift rolling on 35's
08-25-2017, 08:20 PM
#22
Yes even beats Amazon where I usually get everything.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
08-26-2017, 11:04 AM
#23
Originally Posted by eprovenzano
I just used last week... trial setup (I want to permanently attached the antenna to the batwing TV antenna, and run the wire through the fridge vent inot the trailer.) I taped the antenna to the awning arm, and put the brains of the system on my outdoor table. I can say, this unit works as advertised. Without it, I saw one WIFI signal, with it I was able to see 15 different signals. I still need to learn a bit more about the system, but I was impressed as to how well it worked.
You do need to remember one thing... this unit, nor any wifi extender, will make a slow signal any faster... you are at the mercy of the wifi you are connected to. this will connect to distant WIFI signals, but will only communicate at the speed that the WIFI you're connected to can handle.
How did your installation work out. I'd like use my batwing antenna and fridge vent to run the the wire as well.
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
3200 Firman Generator/Inverter
08-26-2017, 11:20 AM
#24
I ran the wire up through the refrigerator chase and bolted it to the vent cap . System works great , pull in wifi that my phone can't see.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
12-02-2017, 11:40 AM
#25
itch'n to road trip
I bought one from Rokland direct and have to get it to work/interface with my MAC book Pro.
2012 Ford F-250 King Ranch Super Crew Cab 4x4
2014 Work & Play 25ULA
Paula Drake, Ken Cooksey, Sunny Delight, Valor & Scarlet Begonia
Jasper Ga.
12-02-2017, 12:27 PM
#26
The new Rockwoods are including a WiFi ranger. I wonder if that is as good as this unit sounds to be.
12-02-2017, 12:31 PM
#27
I have used the WiFi Ranger twice now and I’m very satisfied with how it works. You connect it to the campground’s access point and then tie your devices to it. A great option if your campground limits you to the number of devices you can connect.
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
04-15-2018, 10:45 AM
#28
Just picked this up from Rokland for about 130. Tested it at home laying on a desk and it picked up a ton of access points around me. Trying to figure out how to go about mounting it now....
2017 Georgetown GT3 31B3
N Little Rock AR
04-15-2018, 10:56 AM
#29
Denver To Yuma In 90 Days
I bought this unit at Microcenter for $90 to replace the Wifi card in my desktop which was going haywire.
It is a USB3 AC1750 Wifi router...and it is awesome!
I just clip it to one of my window valances and I'm ready to go!
I am thinking about getting an external antenna for it, but it has worked pretty good in a couple parks with really bad Wifi.
Although where I'm at now out in the desert of southern New Mexico, I'm glad I have a Verizon Mifi Hotspot.
Even with only one or two bars I get a decent speed (I'm on it right now, as a matter of fact).
04-15-2018, 11:06 AM
#30
I just uncovered my camper from it’s long winter nap... installing the WIFI onto the batwing and routing the wire throught the refrigerator chase is on my priority list.
04-15-2018, 11:07 AM
#31
My antenna does not raise up...so...might go with the ladder mount or just use a suction cup and remove it when I leave a site.
N Little Rock AR
04-15-2018, 02:41 PM
#32
I hope I'm not being Capt. Obvious, but I can't help but bring up a couple of cell phone options that take advantage of a WiFi connection that everyone might not be aware of.
I'm not sure about iPhones, but my Android has an internet calling option that is disabled by default. Switching it on will allow you to make voice calls over WiFi, this came in very handy for me a year ago when I was travelling abroad.
The other is an app I'm sure everyone has heard about, it's called WhatsApp and is a WiFi-based texting program. The drawback is that it only works with other phones using the app.
Since these are the only two functions I use my phone for that can't normally be done with just an internet connection I thought they were worth mentioning.
04-15-2018, 02:56 PM
#33
Senior Member - Retired
Internet (wifi) calling is available for iPhones, however carrier participation is required. I use AT&T, not sure but expect T-Mobile and Verizon also support this feature.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
