Old 05-12-2014, 03:26 PM   #1
8801 electric jack control module location?
think i have a bad fuse, cannot find it.
neverhme is offline   Reply With Quote
Old 05-19-2014, 10:33 AM   #2
found under the dinette table.reason i needed to get in there is I blew a fuse on the control module. the plug on the outside corroded and broke, I replaced with a new plug from reico, came with no directions. I ran the remote and wired hot to red positive, turns out the 12v motor runs hot positive and then hot negative to make it reverse and go down, lil fyi for ya, I actually got all four plugs from reico fwiw they could be better quality.Under table I always wanted to add a slide out drawer there. you could still put one on the left side, on right is the module, and red emergency controller.
cat, electric, location, modifications
