Old 05-30-2016, 05:22 AM   #1
Battery disconnect question
2016 Palomino TC battery disconnect question. When the disconnect is pulled out (turned off) what electrical equipment should work inside the camper, 12V, 120V, or NOTHING?
When my switch is pulled, everything works as normal. The wire leads are connected to both terminals of the switch. Maybe I have a bad switch?
Lakeside
lakeside is offline   Reply With Quote
Old 05-30-2016, 05:42 AM   #2
fonzie's Avatar
Usually battery disconnect when pulled out is "on" and when pushed in is "off".....
Name:	push-pull battery disconnect.jpg
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-02-2016, 05:33 PM   #3
Thank you. I wrote my statement backwards.
lakeside
Old 06-02-2016, 05:40 PM   #4
And to add to it if you are plugged in everything will work no matter if the switch is on or off.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 06-02-2016, 05:56 PM   #5
Thanks Toddupton. I will disconnect from shore power and check if the battery disconnect shuts down all battery power to T/C when in the disconnected position.
Lakeside
Old 06-02-2016, 06:02 PM   #6
Rhody's Avatar
Talking
Lakeside
Not to steal the thread But...How difficult is it to install a battery switch
and what is the best location???
Rhody
Rhody is offline   Reply With Quote
Old 06-12-2016, 04:20 PM   #7
OPer update
Had a chance to go dry camping near beautiful Baxter State park this weekend. Got a chance to test battery disconnect.
Disconnect pulled out allows 12V side to work and when pushed in shuts down power to 12V systems providing you are NOT hooked to shore power.
If hooked to shore power everything in camper works.
Thanks all for your assistance.
Lakeside
battery, battery disconnect
