Old 12-17-2018, 08:15 PM   #1
Do I Need A Truck Bedlner
Will I need some sort of bedlner in the bed of the truck to help protect it from the camper? If yes can you recommend what to use and where to get it. Thanks.
Baysailor is offline   Reply With Quote
Old 12-17-2018, 10:55 PM   #2
Would recommend LineX. Just don't watch them install it. I had brand new truck that I had done and before I left the dealer they were out grinding off all the paint in the bed. Arghhh.
Looked great when they were done and still looked great when I sold the truck 6 years later. Have them do top of the bed rails if you get it done.
Should be able to google for dealers in your area. Also can check on Line X (and Rhino Liner). After research I decided on the Line X and was never sorry I did.
Due to depreciation the above opinion is now worth less than what you paid for it.
Everyone is good at something... I happen to be a good bad example.
2016 Forester 3011DSF
Oregon is offline   Reply With Quote
Old 12-18-2018, 12:00 AM   #3
Oregon, Besides the LineX did you put any other type of protection down in the bed of the truck before placing the camper into it? The Palomino dealer I’m speaking with is talking about some product to put down, I think it’s like a rubber pad of some type. $650! One of the workers grabbed me and said I could do it for under $100 if I bought the product myself online but I can’t recall the product he was referring to. He said it’s used in horse trailers, is one inch thick, and I think he mentioned it was a rubber type material. Any thoughts?
Old 12-18-2018, 12:54 AM   #4
Denver To Yuma In 90 Days
I paid $200 for the two rubber mats...one for the bed and one for the tailgate.
Bought them both from the shop where I bought the topper for my truck before I switched to a 5'ver!
Probably all you'll need!
ID:	193202   Click image for larger version
JohnD10 is offline   Reply With Quote
Old 12-18-2018, 05:25 AM   #5
rmillermtsu's Avatar
I’m very ocd about my truck bed so take my advice with a grain of salt. I have used Linex with great success on my last three trucks. I even had my dually fender wells coated with it. In addition, I top the bed with a rubber bed mat when not towing our fifth wheel. I bought some cheap horse stall mat and cut it to fit when towing the 5th wheel. This stuff comes in 3’x4’ sheets at Tractor Supply. Good luck! Rick
2019 Chevy 3500 LTZ 4x4 DRW// Factory Gooseneck Prep// Andersen Ultimate Hitch
2018 Classic Super Lite 8528RKWS
2015 F250 6.2l Lariat 4x4 3.73's (Sold)
2016 Micro Lite 25DKS (sold)
rmillermtsu is offline   Reply With Quote
Old 12-18-2018, 07:11 AM   #6
Georgia Rally Coordinator
aceinspp's Avatar
I'd definitely do the spray in bed liner. Its well worth the money. I've had this done to the last 5 trucks I've owned. Last 3 I had factory spray in liners as the cost was the same as having done by an out side source. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 30
Old 12-18-2018, 07:58 AM   #7
Ejs4029's Avatar
I had a Rhino liner in my previous truck and my current truck has the factory spray in liner I would recommend either or
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is online now   Reply With Quote
Old 12-18-2018, 08:03 AM   #8
Rhino or LineX. The dealer had some local paint shop do my GMC and the edges are starting to peel up. Had LineX on my Silverado and beat the crap out of it hauling gravel....washed it out and it still looked great.
TheWolfPaq82 is online now   Reply With Quote
Old 12-18-2018, 08:18 AM   #9
To answer your original question... do you NEED a bedliner of some sort to install a truck camper?.... no you dont.
Do not let the dealer sell you something don't want.
Will you protect the finish on your truck bed if you do install some kind of liner?... sure!
I had a truck camper in two different trucks without bedliners and in one with. Other than a few rub marks from sliding the camper in and out, there really wasn't any difference.
You've received good advice about spray in liners and mats. If you want your truck bed to stay pristine, put something in it.
I've always used my trucks as trucks so a few scratches and scrapes didn't really matter.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 12-18-2018, 08:54 AM   #10
WFD
Baysailor...this is typical of the "Stealer" trying to upsell you on something you really don't need, or if you do need or want, charging a ridiculous price for it. You have received good advice here about getting your own product or doing the spray in. I have had both Rhino and factory spray in, both have performed equally well. The recommendation for spraying the top of the box rails is a very good one, glad I did that to mine!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
bed, truck
