Old 10-20-2017, 07:33 PM   #1
Wallyvision's Avatar
Hot water
SS-1251 does the hot water heat up only with propane? I see the heater switch inside, but wondered if you need propane or just power? Thanks
Wallyvision is offline   Reply With Quote
Old 10-20-2017, 07:41 PM   #2
wmtire's Avatar
If you have a dual powered Suburban water heater, this thread may help you in where to look for an electric element switch (if equipped)
http://www.forestriverforums.com/for...ore-36197.html
Most likely though, you have a propane only water heater, which just requires propane and a form of 12 volt DC.
2011 Flagstaff 831 RLBSS
Old 10-22-2017, 02:29 PM   #3
Easy way to check. Turn valve off at propane tank and see if you can get hot water.
Pretty sure the on demand heater is propane. I use it dry camping a lot and haven't killed my batteries yet...
fwisor is offline   Reply With Quote
hot water, water
