Old 10-20-2017, 07:33 PM   #1
Wallyvision's Avatar
Hot water
SS-1251 does the hot water heat up only with propane? I see the heater switch inside, but wondered if you need propane or just power? Thanks
Wallyvision is offline   Reply With Quote
Old 10-20-2017, 07:41 PM   #2
wmtire's Avatar
If you have a dual powered Suburban water heater, this thread may help you in where to look for an electric element switch (if equipped)
Suburban's electric switch and much more
Most likely though, you have a propane only water heater, which just requires propane and a form of 12 volt DC.
2011 Flagstaff 831 RLBSS
Did you know, according to Google: Pepsi was once the 6th largest military in the world?
Old 10-22-2017, 02:29 PM   #3
Easy way to check. Turn valve off at propane tank and see if you can get hot water.
Pretty sure the on demand heater is propane. I use it dry camping a lot and haven't killed my batteries yet...
fwisor is offline   Reply With Quote
hot water, water
