Old 11-16-2016, 08:19 PM   #1
House batteries...
Kind of a general question actually... My TC has it's battery in a battery box. If I removed the plastic box entirely, I have enough room to put in 2 batteries wired in series. Do the batteries have to be in a battery box, is that a requirement or can I secure them in the compartment (under the dinette seat) without the bulky plastic battery box? The compartment is vented, however, my Xantrex is inside as well as the water pump and fresh water tank...
Just not sure and need some advice. Thanks in advance...
SidecarFlip is offline   Reply With Quote
Old 11-20-2016, 11:01 AM   #2
hobiekaw's Avatar
I would like to do the same. Have you tried contacting palomino to see if it's possible?
hobiekaw is offline   Reply With Quote
Old 11-20-2016, 12:04 PM   #3
Not sure what type of batteries you are planning on putting inside the trailer but if they happen to off-gas I wouldn't want anything electrical in the vicinity that has the possibility of creating a spark, however small the chance may be. Remember the Hindenburg???
2010 Wildwood XLite 26BHXL
2013 Ram Outdoorsman 5.7l
Ontherock is offline   Reply With Quote
Old 11-20-2016, 03:56 PM   #4
bikendan's Avatar
The OP has a truck camper, not a trailer. So the battery has to be inside.
Equalizer WDH
Old 11-20-2016, 05:02 PM   #5
In series?.........something you want to run on 24 vdc?
Trevor43 is offline   Reply With Quote
Old 11-20-2016, 07:31 PM   #6
Trevor... I want to run 2 6 volt golf cart batteries in series or 2 12 volt in parallel. Should have been more clear.
The battery compartment is vented and I'm thinking of removing the plastic battery box and maybe building a box from plywood to fit 2 batteries and employing the existing vents if I cannot just install a second battery and not vent it...
The supplied battery box is way larger then the supplied battery but no where big enough for 2 batteries.
I'm going to call Brian Hayward at Palomino tomorrow. I got a recall notice (of all things) in the mail this morning concerning my SS1500.
My main impetus for 2 batteries is I run a Xantrex Pro-Sine inverter to power my CPAP machine, and while the one battery runs it all night, I cannot run the humidifier all night as well. Just not enough amp hours in one battery available.
I can run the inverter genny all night but I don't want to. I like it quiet.
The other modification I'm going to do is add knee wall access doors so I can access the space between the camper and the truck bed for storage. Brian has already provided me with doors and sheared to size exterior sheathing to match the underside of the camper (black pebble grain sheet) so everything looks factory.
The camper is inside my heated shop so working on it in the winter is a non issue. I don't even winterize it. The shop never gets below 50.
I didn't realize it lacked knee wall doors when I purchased it. My old Lance had them and I used them all the time. Lots of 'dead' space between the camper and the truck bed for storage....
Old 11-20-2016, 08:01 PM   #7
hobiekaw's Avatar
Maybe you could put the second battery outside the camper in the truck bed?
Old 11-20-2016, 08:32 PM   #8
I see that e-trailer has one that fits in the inside frame rail of our Ford trucks and that might be am alternative.
