Old 10-27-2015, 10:14 PM   #1
LTM
HS6601 Electric Jacks
I have had an HS6601 with Rieco Titan electric jacks for two years. This past weekend, the jacks did not respond to the remote (wired and un-wired) when I needed to unload it at the campsite. I was going to check for a thrown breaker or other problem before using a wrench to lower manually. I can't find the receiver control box. I looked in every removable panel with no luck. I tried to trace the signal wire from the remote control panel but was unsuccessful. After spending awhile looking for the control box, the jacks began working again. I do want to know where the control box is in case I need it in the future. Can anyone point me in the right direction?
LTM is offline   Reply With Quote
Old 12-08-2015, 08:47 PM   #2
hobiekaw's Avatar
I found the control box and an emergency control under the dinette floor. Remove 4 screws and lift it up.
hobiekaw is offline   Reply With Quote
electric, jacks
