Old 01-06-2018, 07:53 PM   #1
L&w crank lift gear broken
The gear that connects to the passenger side of my palomino bronco 1500 made by L&w engineering broke in half. Now the passenger side of the camper will not pop up.
Does anyone know where I could find this gear.
ID:	159677   Click image for larger version
ID:	159678   Click image for larger version
ID:	159679   Click image for larger version
ID:	159680   Click image for larger version
Palomino2011 is offline   Reply With Quote
Old 02-10-2018, 10:35 PM   #2
BooBoo23's Avatar
Check McMaster-Carr. Give them a call, you will need to know the number of teeth and shaft size, width and whatever info they may need. Keyed on the shaft or pinned? https://www.mcmaster.com/#gears/=1bimlxz
If they don't have a replacement they may know who does.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 02-20-2018, 06:30 PM   #3
hobiekaw's Avatar
Check with L & W they may be able to provide replacement parts
hobiekaw is offline   Reply With Quote
Old 02-20-2018, 08:31 PM   #4
Thank you everyone I found a place called canvas camper repair they're a great resource but I decided to scrap the whole crank because I couldn't get it to work and I have automated the whole system it now runs on remote control and is lifted by lineal actuators
Old 04-09-2018, 01:09 AM   #5
Would like some information on your modification
To lineal actuators model are were you got them
jseng is offline   Reply With Quote
Old 04-19-2018, 01:23 PM   #6
I got the actuators from windynation you can wire them directly and they sell. A remote with their system. Each actuator is 20" and can lift 250 lbs.
I opted to splice them into the reico system instead of hassle with wiring. It's lready wired in clean and has a remote. I can adjust each actuator to dial the roof tilt and height in. I spliced off ireing and left a plug so when I need to lift the camper I disconnect the roof lift and plug in the reico camper lifts.
Make sure you keep a new battery as mine was old and led to a comical debacle one trip out. Now I take better care of my battery and it's a non issue.
Windynation.com. The guys there are really helpful. Tell em John sent ya.
lift
