Old 05-26-2014, 11:20 AM   #1
M2902 palomino fresh water tank drain?
Anybody know where water tank drain valve is located on this camper? I've looked at can't find it, I guess I'll just use water pump to drain into gray tank if no one can advise here
racer2 is offline   Reply With Quote
Old 06-14-2014, 07:55 AM   #2
look at the bottom of the camper. you will see a drain hole. the valve is right above the hole inside.
Shawn8801 is offline   Reply With Quote
Old 06-14-2014, 08:10 AM   #3
Ford Idaho's Avatar
Ya, under the trailer there should be a tube with a cap on the end of it.
You may find a tube with no cap which might be the fresh water overflow tube.
drain, fresh water, palomino, tank, water, water tank
