Old 09-05-2017, 12:55 PM   #1
Pop-up
Can the " potty "be used without raising the top ?
What is the difference between a "porta potty and a cassette toilet ?
Thank you
wanderingbob is offline   Reply With Quote
Old 09-05-2017, 01:28 PM   #2
WolfWhistle's Avatar
Thank you
I don't have a popup, but would imagine that to get inside for the potty, you would have to raise the top.
A cassette toilet is permanently mounted; might be at an unusual height, but doable... essentially the same as an RV toilet using a black tank. The one I have, has its own small water tank for flushing (probably around 4 gals) and a pump. The cassette is actually the removable tank, usually 5 gallons accessible from outside the unit. I had my doubts about liking it, but it is great. You can dump into any toilet, you don't need to find a dump station. My tank is even on wheels, although 5 gallons isn't hard to carry.
So far, I have dumped numerous times and haven't so much as a drop on me or outside the targeted toilet
Here a link to a porta pottt, which I don't see as a major issue for use. I only to urinate, thus far. And, plan to keep it that way.
https://www.walmart.com/ip/Thetford-...&wl13=&veh=sem
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 09-05-2017, 02:28 PM   #3
Broken Toe
Cowracer's Avatar
Unless you are a contortionist, there is no room to use the toilet with the top down and the beds in, even with a high-wall.
I have had a cassette toilet on my old PUP, and I have a porta-potty in my cabin (thetford curve) and there isn't really a difference on how they work or are dumped. The only diff is that the cassette toilet is pretty much permanently attached, and the porta-potty is... well.. portable.
Either way, properly used they are virtually odor free. Just make sure you use flush water EVERY time you flush. It's tempting when you just take a leak to only open the valve to drain the bowl so you don't have to empty it as much, but its FAR more pleasant to dump 2 tanks of 50% water/50% urine than it is to dump 1 tank of 100% urine.
tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 10-04-2017, 05:48 PM   #4
I am the original poster !
I have since purchased a Palomino soft side and YES , I can use the potty with the roof down , I am 6 foot tall . The hard part is getting your pants back up .I am thinking of only camping at nudist campgrounds to alleviate this problem !
Old 10-05-2017, 04:48 PM   #5
Okay I give. Knowing what I know about popup campers I would really like to know how one uses the potty without raising the roof and pulling at least one bed out.
I am not that tall but there is no way I could do anything except crawl around on my hands and knees under those beds. Also I was thinking most potties in a popup have some type of cabinet top that needs to be lifted to use.
I do not personally plan on using one with the top down but I sure would like to store up the knowledge of how its accomplished just in case.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 10-05-2017, 09:28 PM   #6
bikendan's Avatar
Since this is posted in the Truck Camper section and he owns a Palomino, he has a popup truck camper, made by Palomino.
It's not about a popup trailer.
Palomino is the only FR division that makes truck
campers.
Equalizer WDH
