Old 06-21-2015, 10:08 PM   #1
Unhappy Raising the Roof problem
I have a 2006 Palomino Bronco 1251 Slide-in Truck Camper. The problem I have now with it is the rearend of the roof does not go quite high enough to allow the rear top panel to fold up into place and connect the door to the bottom half. It has just started this recently, anyone else have this problem and how do you fix or adjust this problem.
Thanks for any help.
Duvie is offline   Reply With Quote
Old 07-02-2015, 01:54 PM   #2
hobiekaw's Avatar
I had that problem on my 2012 a couple of times and I just forced it up high enough to get the door to function. Last year the lift system failed and we replaced it. The springs in the tubes were dry and I think that caused the failure. We greased the heck out of the new system. You may want to pull the lift mechanism off and grease everything really well and see if that helps.
hobiekaw is offline   Reply With Quote
roo, roof
