Old 09-15-2018, 09:29 AM   #1
Real Lite Roof Latches wonít tension Enough!
Hello, I recently bought a Real lite 1608 and when I lower the roof down and tuck everything inside appropriately I canít tighten the latches enough to provide enough tension so they come right off the lip and flop down. The tension screw is in as far as it will go. This isnít on all the latches but two of the 4. Has anyone experienced this?
ColoradoCub is offline   Reply With Quote
Old 09-15-2018, 10:13 AM   #2
hobiekaw's Avatar
Have you contacted that dealer or palomino? You may have to move the whole latch down.
hobiekaw is offline   Reply With Quote
Old 09-15-2018, 10:32 AM   #3
Latches
I didnít buy it from a dealer and donít have a dealer near by. Itís a 2013, Iím thinking I almost have to unthread the tensioner screw and grind off a 1/4Ē of it so I can tension it at this point since it bottoms out before there is enough tension. I surely donít want to drill new holes and lower the latch box.
Old 09-15-2018, 10:44 AM   #4
hobiekaw's Avatar
I had a 2012 1251 but never had problems with it latching. I don't remember exactly what the latch looks like. Is it possible to replace the threaded portion?
Old 09-15-2018, 10:46 AM   #5
hobiekaw's Avatar
Or contact the factory. When I have had a problem, they have been quick to respond.
Old 09-15-2018, 10:53 AM   #6
Contacting the factory might be an option, thanks.
lite, roo, roof
