First release any pressure using the safety valve. Then remove either anode rod or the nylon drain plug ( from the outside access). Be sure the electric HW switch is turned off before draining. If you have an anode rod, you may need a breaker bar if it has not been out for a while.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
