Old 11-24-2014, 07:50 PM   #1
joep218's Avatar
Winterizing!
Just a quick question here. I am winterizing my camper and can't figure out how to drain the water from the hot water heater.
Any help? Is this on the outside panel?
joep218 is offline   Reply With Quote
Old 11-24-2014, 07:59 PM   #2
Flybob's Avatar
First release any pressure using the safety valve. Then remove either anode rod or the nylon drain plug ( from the outside access). Be sure the electric HW switch is turned off before draining. If you have an anode rod, you may need a breaker bar if it has not been out for a while.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
winter, winterize
