Old 08-31-2008, 04:29 PM   #1
04 Flagstaff 26 lite
My slideout wont retract, does not seem to have any power to it, are there fuses or breakers for it & where would they be located. Everything else electrical in the trailer works.
Thank you,
Bob
bob garber is offline   Reply With Quote
Old 08-31-2008, 05:56 PM   #2
Stuck
I cant get it home, any help.
Old 08-31-2008, 08:04 PM   #3
You may have to retract it manually. Not quite sure how though. Which model Flagstaff do you have?
Hokiehall is offline   Reply With Quote
Old 08-31-2008, 08:25 PM   #4
Its a 26 DS
Old 08-31-2008, 08:54 PM   #5
MRimmer's Avatar
26 ds should be 12 volt slide not huydraulic if I am correct.
Check the 12 volt system for power
Battery Power?
Fuses in the power panel?
Battery down or bad caused this same problem on my brother in laws unit.
Sorry I can't offer more help at this time
Mike
MRimmer is offline   Reply With Quote
Old 08-31-2008, 09:12 PM   #6
This is an image of some instructions I downloaded from the manufacturer's site that supposedly made my slide. I'm not sure this will help you, but it might if it is the correct model.
Old 10-05-2008, 08:09 PM   #7
Fuses/ breakers are located in the panel under your refridgerator The cover is vented and has a small black knob at the top, turn that knob and the cover will drop down, the fuses are located there. If you don't find a blown fuse or breaker, go under the slide and look for the gearing. There is a way to manually retract the slide by rotating a nut or bolt. If I remember from looking at the one I just traded '03 26DS, i decided it would be a pain but could be done. I hope this helps
Steve
Cedar Creek Steve is offline   Reply With Quote
