Forest River Forums
Sunline User Photos
Old 11-03-2011, 07:21 PM   #1
05 Cherokee 27L No Shore Power!
Alright guys, need a hand here, last time we used are camper, everything worked fine, now I want to use it this weekend and no shore power, zilch, nada. breakers and fuses at main panel fine, 2 little breakers under the tongue are fine. I have battery power, but no 110. any ideas???
stevenmacc is offline   Reply With Quote
Old 11-04-2011, 09:39 AM   #2
too fast turbo sled
f1100turbo's Avatar
Have you checked to see if you have 110 at converter?
need to start there first.
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (2)
f1100turbo is offline   Reply With Quote
Old 11-04-2011, 10:23 AM   #3
Check your GFI(s) . Also make sure that your source power does not have a tripped circuit breaker.
... VTX-AL
VTX Al is offline   Reply With Quote
Old 11-04-2011, 11:02 AM   #4
too fast turbo sled
f1100turbo's Avatar
What 110 power do you not have? I know you said zilch but did you check The outlets?
If that's true then gfci plug ins are next on your list.
Id seriously check for power at the converter box because if you have no 110 there that means your battery charger isn't working either.
Also would be nice to know what if any diagnosis you've done
Ron and Amy Benhart
Old 11-04-2011, 07:19 PM   #5
Here we go, I have 12 volt power, I have 110 power at the cord, then I plug into the camper, and no 110 in the camper, no 110 at the junction box, but power on the 12 volt side. no circuit breakers are tripped. So, no outlets, no microwave, no a/c. Is there anything inline under the unit from the plug in to the junction box??
Old 11-04-2011, 07:24 PM   #6
I had the same problem last week. The culprit turned out to be the GFCI outlet I was using in the garage. I replaced the outlet and all is well. I hope your problem is that simple to fix!
James and Karen
Warner Robins, GA
2011 Lacrosse 301RLS
2007 Tundra CM 5.7
Reese Dual Cam
jjarrard is offline   Reply With Quote
Old 11-04-2011, 07:26 PM   #7
Me tto, but I have pwer all the way to the camper end of the cord, and its plugged into a non GFCI outlet.
Old 11-04-2011, 09:46 PM   #8
too fast turbo sled
f1100turbo's Avatar
checked power at the converter yet ?
Ron and Amy Benhart
Old 11-04-2011, 09:51 PM   #9
Yes, I've checked the converter, I have 12 volt but no 110, so problem is between plug and converter
Old 11-04-2011, 09:57 PM   #10
too fast turbo sled
f1100turbo's Avatar
ok .
on mine there is a junction box shortly after where the 120 volt line comes in,
there has to be a bad connection there if you have one .
Ron and Amy Benhart
» Online Users: 240
13 members and 227 guests
BigDogD, cardinal4fun, dangerranger363, hotrodj125, Leathergypsy, mblanks2, mrthumper24, navypoppop, nrcamp, papap, stevo, Unruly, Vernk
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
