Old 04-17-2009, 05:53 PM   #1
08 Rockwood Tent Rig
I have had nothing but trouble out my 08 camper. Dealer fault, though. Just picked it up from 6 months in service at dealer, went camping and the propane will not flow any where, stove, frig, furnace, or grill. tank was filled when rig left the dealer.....any info would be helpful!
RockwoodonFrogsCreek is offline   Reply With Quote
Old 04-18-2009, 12:28 AM   #2
Sounds like a regulator problem to me but i am not familar with the FR pop up.Also are you sure the dealer filled it or just said they did .Did you try and hook up a different tank or hook that tank from the camper to a grill or something to rule out tank failure? I am just throwing thoughts out here .There cant be to much to the system tank, hose, regulator and since your not getting fuel to anything it has to be in tank or regulator. Sorry cant be more help but hang tight someone else will post that can be more helpful
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 04-18-2009, 08:49 AM   #3
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Your problem is likely the overflow protection device on the tank, known as the OPD. Try this simple fix: close the valve on the tank, wait a few minutes and the open the valve slowly, slowly being the important part. Open a burner control on your stove and light. It might take a few seconds for the gas to reach the burner. Costs you nothing to try, so go for it.
dimurrrw is offline   Reply With Quote
Old 04-18-2009, 06:14 PM   #4
Thanks for the input. Will take your advise, just so frustrated with the dealeship...ect. Will let you know the results!
Old 04-19-2009, 02:30 PM   #5
Head Rambler
It could be the excess flow preventer(s). If the valves are opened too fast there is a device that almost shuts the flow from the cylinder off completely. Close the cylinder valve all the way, wait a few seconds then S L O W L Y turn the valves back on. If it's not that try removing the acme nut and replacing it securely. If it's not that, it's more than likely the regulator.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
