08 Sabre 28 rets
We bought this unit used. I noticed that the shower door you had to lift to get it to shut. Which means that the unit is leaning on the hinge side. I lifted up the door and it would move from the wall. So I took the panel out thinking that te screw in the rail had backed out. Um no they screws the rail to the paneling and put the stud about 2-3 inches away from the rail. Sounds stupid and not sure what dummy approved this. So the only way to fix would be to tear out shower unit, tear paneling out, install a stud. I also thought to run a 3-4 inch screw all the way through the wall and put a plate at top of the kitchen cabinets. The problem there is there is a wire chase there on the kitchen side of the wall.
Anyone have any other ideas?
Thanks for any and all comments
Bruce
