Old 12-27-2015, 02:57 PM   #1
115v connection outside
Okay, i've had a few rvs,...but never seen this. I have a 2002 sandpiper 30bhss,..back where the 30amp shore cable is,....there is a 115v connection(male) beside it. Being male connections,....is that a place to run just a 115v cord for basics if need? Another question,... mine is cable ready,..why are there two cable connections outside?
longracing25 is offline   Reply With Quote
Old 12-27-2015, 03:17 PM   #2
DaveSchwartz's Avatar
If its a used trailer, a previous owner probably installed a dedicated 115V inlet port for things like a space heater. There is currently a thread going on about that here. There's probably a pigtail or outlet somewhere that is not active until an outdoor extension cord (you should use a heavy-duty 12-guage) is connected from the power post 115 outlet.
As far as the cable, one is for external park cable (which switches alternately with the rooftop antenna via the push button on the booster) and the other will be for satellite. The satellite is separate so you don't inject power to a cable system.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 12-27-2015, 03:24 PM   #3
ahh,..okay. The 115 connection looks factory to me. It's in a recessed little round opening with a cover
Old 12-27-2015, 05:52 PM   #4
Mr. Dan's Avatar
Members here are doing pro-looking jobs adding these openings. See the link DaveSchwartz mentioned.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 12-27-2015, 06:16 PM   #5
Bluepill's Avatar
Yup, great design to get 45 amps instead of just 30.
2008 Itasca Meridian 37H
Old 02-06-2016, 09:07 PM   #6
RangeMaggotBob's Avatar
In case you haven't figured it out yet- satellite connector on the right, and cable TV connector on the left. At least it's that way on ours.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
