Old 06-30-2010, 09:48 AM   #1
12 volt ceiling fan stops
He we have a 2009 Salem SMT 403FBLTD trailer which we really enjoy.
The optional 12 volt fan (not part of the air conditioner) Stops over night . Don't now how long it runs but when we get up it has stopped but the switch is still in the on position. i think that if the fan was over heating then it would restart on it's own when the thermo cut off resets but this doesn't happen. When we turn the switch off then on, the fan starts and runs for hours again.
This happens over and over.
What needs replacing? Any similar cases out there?
regards Fred
fmielke is offline   Reply With Quote
Old 06-30-2010, 11:17 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Is it a Fantastic Fan? They have a temperature adjustment knob to bring the fan on when the temperature rises. The more toward the blue line the longer it runs. Our fan has 3 speeds and off. If it's set on anything other than 0-off it will cycle on and off if the top is opened.
FanTastic Vent - Products
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 06-30-2010, 11:52 AM   #3
Hello, no it is not a fantastic exhaust fan, just a regular 4 blade 12 volt ceiling fan.
Old 06-30-2010, 12:16 PM   #4
cfsoistman's Avatar
Maybe it has a thermal safety that kicks it off but power to the safety has to be interupted for it to reset.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-26-2010, 10:48 PM   #5
Update: cure to stopping fan
Forest River supplied a new wall switch as it was getting quite warm before it would cut out and stop the fan. The replacement switch, still gets a little warm but now the fan no longer shuts off. Also the insulation in the wall allowed for no heat dissipation. Hope the new switch will not fail.
The switch is rated at only 20 watts which I think is a little low.
Old 07-26-2010, 10:58 PM   #6
20 watts at 13 volts equals 1.54 amps. Would be nice to know what the current for the fan is on high speed, which would be max current draw. Also, since it is a DC fan, are they controlling speed with resistors that are part of the switch, and do they have the proper wattage rating? The resistors may be what is generating the heat. If it quits again, turn it to high and let it run, as this should by-pass all the speed control resistors. By the way, this trick also works for the blower fan in your car.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 07-27-2010, 06:27 AM   #7
KyDan's Avatar
Are you SURE it doesn't say rated at 20 AMPS???
Old 07-27-2010, 06:44 AM   #8
Herk7769's Avatar
I will get an amp reading at different speeds sometime today and post tonight.
HAM CALLSIGN - KC3FFW
12 volt, fan
