12V interior wiring
Checking camper before leaving for winter found factory wireing that I think is not good.#6 wire that is used from conveter to batteries for charging negitive wire was cut and put together with wire nut along with a short piece of #12 wire that was used to connect.with wire nut, all negitive wires for interior 12V.The wire nuts were taped and pulled off easly were not twisted on wire.I mounted a ground bar next to converter and terminated all wires in it.Lites do not seam to flicker as much now.If you are having problems with interior lites or batteries charging may want to check.Sorry for long post
Dave&Eileen
