Old 08-26-2016, 04:27 PM   #1
NOREASTRV's Avatar
20 amp
Need some advise, I found one camping spot left at a campground over labor day but it shows it as being a 20 amp site and my camper is 30 amp, any issues?
Tom and Julie
2015 Rockwood 2703WS Emerald
2012 GMC Sierra Crew 4x4 1500 SLT Z71
NOREASTRV is offline   Reply With Quote
Old 08-26-2016, 04:30 PM   #2
fonzie's Avatar
Issues? You will need a 30 to 15/20 amp adapter. You will have to manage your electricity use more closely otherwise will trip 20 amp breaker: will not be able to use AC with microwave or AC with water heater etc etc...you should be able to manage....also watch that hair dyer...
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 08-26-2016, 04:34 PM   #3
NOREASTRV's Avatar
Thanks for the quick response, I'm good with the adapter, I can always run fridge off propane if needed, my concern is my 15000 btu a/c I was told by the dealer never run the a/c when plugged in at home so I thought this would be similar to doing that, I don't want to damage the a/c with low power current
Tom and Julie
Old 08-26-2016, 04:38 PM   #4
fonzie's Avatar
If you run the AC, then yes run everything else on propane. Your converter always use 2 to 8 amps for 12 volts load and battery charging, but you should be OK.....your AC uses about 15 amps running......
Fonzie
Old 08-26-2016, 04:39 PM   #5
NOREASTRV's Avatar
Thank you for the help
Tom and Julie
Old 08-26-2016, 04:46 PM   #6
TURBS's Avatar
20 amp
Might not even be able to use a/c
Without a ems I wouldn't even try it
My 15k a/c draws 18 amps all day long.
Your converter is a constant at 2-8 amps
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "32"
Old 08-26-2016, 04:46 PM   #7
fonzie's Avatar
If you want more info on voltage, I would monitor voltage inside trailer with one of these.....anything below 108 volts when AC is running would be a concern....
https://www.walmart.com/ip/Camco-RV-...Meter/29764594
Fonzie
Old 08-26-2016, 04:48 PM   #8
Dealer gave good advice too a point. If you just want to charge the batteries or run the fridge you should be ok, but most outlets in a home are wired on a 15amp breaker and #14 wire. This will not run the A/C, or if it does, not for long, and you hope the breaker trips before the wire gets to hot. A 15,000 A/C needs to be on a 20 amp circuit which requires #12 wire also dependent upon the length of wire. One thing us RV owners should consider is adding an RV box for home use because one day, sooner than later, you will need to power the RV at home. Be safe.
BBQGUY is offline   Reply With Quote
Old 08-26-2016, 05:16 PM   #9
I also wouldn't do it. The AC could be to much.
It will to hot without your AC. I installed a 50 AMP at
my home.
whj77372 is offline   Reply With Quote
Old 08-26-2016, 09:53 PM   #10
NOREASTRV's Avatar
Thanks to EVERYONE for your advise, I found one last site elsewhere that just opened up with a 30 amp so booked it, I have learned very valuable info and appreciate your help!!
Tom and Julie
