Old 01-09-2011, 03:03 PM   #1
2006 Surveyor 303 Floor Replacement
Hey guys I have to replace a small section of floor on my 2006 Forest River Surveyor 303 it toward the back in front of the frig and was wonder what size the plywood is and what a good replacement would be. Any other info on doing this would be great.
ramit315 is offline   Reply With Quote
Old 01-09-2011, 07:22 PM   #2
sherdep's Avatar
Welcome to the Forum
Is the floor soft from getting wet?
You may get diffrent opinions on this -
If it is a moisture issue I would suggest either Marine Plywood or pressure treated with some sort of water seal - not sure of the size you need
Can you take a picture of the area you are trying to replace - you may need to remove some stuff around it so you can get larger area to secure the new piece you are replacing
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 01-10-2011, 06:35 AM   #3
Head Rambler
I'm not sure they're the same but our Grand Surveyor uses 1/2" plywood flooring. It's actually not 1/2" it's really 15/32" but it's standard trade size so close enough. You're probably going to need to shore up around the edges where you cut the patch out but that's easy to do.
Gotta go campin!
Old 01-12-2011, 01:32 PM   #4
Thanks guys. I had a leak in the bathroom under the sink that made the soft spot. I will try next week to get to replaceing the floor.
