Old 06-09-2010, 03:33 PM   #1
2008 Rockwood 8313SS
We are having problems with the bolts breaking on the slide out for the den??? ANybody else
n2lsu2 is offline   Reply With Quote
Old 06-09-2010, 04:11 PM   #2
Yes that is a very common problem You need to replace them with a a hardened bolt not a stainless bolt but a hardened bolt Also Welcome to the forum
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 06-30-2010, 01:41 PM   #3
Now the front two speakers in the den area are not working. Im thinking we may have to check the wiring behind the radio itself - which naturally is behind the wall. Took the speakers off the ceiling and that wiring is fine.
Just had the end cap replaced and they did a crappy job sealing the new one so now it leaks. And they tell us we should have checked it - well hello we cant tell if it was gonna leak till it rained.
And naturally all of this happens after the warranty goes out.
Rockwood 8313SS
Chevrolet 2500 HD
Old 06-30-2010, 01:53 PM   #4
milzat's Avatar
Slide Bolt Shearing Problem and Solution
milzat is offline   Reply With Quote
8313ss
