Old 11-29-2009, 11:11 PM   #1
Fishfireguy's Avatar
2010 Surveyor SP 186- Shower Leaking
We just returned from our first major outing and discovered what I believe to be a major design flaw concerning the shower in this unit. The plastic shower wall overlaps the plastic shower bottom. Even if the trailer is level, water runs out onto the floor. There is no way to prevent it. Eventually this will cause the floor to rot. As it is, I can't see how to fix it short of replacing it with a solid plastic unit. I love this trailer but am upset that this shower has been so poorly designed. Even adding shower corners are impossible based on the way this is set up. Any ideas on how to approach this? Our dealer is outstanding so I'm really hoping he can find a remedy for this.
Fishfireguy is offline   Reply With Quote
Old 11-30-2009, 04:10 AM   #2
Commercial Member
huntr70's Avatar
Try putting in a pleated shower door or a shower screen to replace the curtain.
Worked great on our Outback and kept all the water in the tub where it belongs...
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 11-30-2009, 11:10 AM   #3
NWJeeper's Avatar
Do a search for "shower leaking" here on the forum, there has been a few threads on it in the past, there may be some good solutions to be found there...
Ed & Wendy
www.nwjeepn.com
Old 11-30-2009, 01:46 PM   #4
I have the same camper with the same problem. One other member i have been conversing with also had the same problem. My fix was to caulk the gap and slope it forward building up the caulk on the end. Has worked fine so far. But I plan on getting those plastic corners. Better than shimming the whole unit. Let me know if you come up with something better.
KegStealer is offline   Reply With Quote
