03-29-2019, 03:32 PM
#41
Originally Posted by VABob
By now you probably already started the repairs and settlement. As with a vehicle you need to ask for loss of value. The resale cost goes down after an accident and the loss of value (resale value) should be sought in any settlement.
X2
That damage is more than skin deep. Those recommending local repair etc etc. It's his trailer, he's a proud owner and deserves the best repair possible. If that means taking it Indiana so be it. Chances are it will be taken care of correctly. Much better than a 2nd rate patch job. The trailer was perfect when it was hit.........the owner has the right to have it made perfect again.
04-01-2019, 10:42 AM
#42
Originally Posted by dangrega33
Sorry to hear about your camper! Wherever you take it, make sure they get it done fast because that is a whole season down the drain if you cant get it back soon! Manufacturer will probably fix it the best, but will take forever. Take it to a certified RV repair shop and they should fix it quick!
Quick question, what is that plastic tire cover? Where did you get it and how much?
Tire cover came with the trailer. Standard equipment for the Rockwood Ultra-lights
04-01-2019, 10:53 AM
#43
Update: Meeting with the Trucking company Insurance adjuster this week (Progressive). I found a repair shop in Sacramento CA that specializes in trailer and coach body and repair. Since fridge is on that same back wall, he is recommending replacing fridge also. He does work on very expensive coaches, interior and exterior, so he may be a good choice for me. He is recommending replacing back wall and doing fiberglass repair on side wall, stripping off all decals, blending the repair and clear coating the whole left side, replacing decals over clear. Estimating 3 weeks, most of that time is waiting on decals from FR.
#44
Sounds like a plan.
Keep us posted.
04-04-2019, 10:10 AM
#45
Update: Dropped off the trailer yesterday afternoon for repair and met with trucking company's insurance adjuster. Mike at NorCal RV Body in Sacramento, CA seems to really know his stuff. He happily gave us a tour of his facility and whats being worked on there. Several Diesel pushers and a few trailers getting some major reconstruction work done there. We learned a lot in the hour we spent with him on how to keep up with maintenance on these trailers(common point of failure, etc), Looking forward to updates and seeing the end result.
04-04-2019, 10:24 AM
#46
Sounds like you found a great repair facility that you are comfortable with! Congrats and best wishes. Keep us updated on progress. Thanks!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
04-04-2019, 02:19 PM
#47
This turned out much better than it could have. It's great that there's a place available to you.
Gotta go campin!
04-05-2019, 08:24 AM
#48
I would love to know ( the common points of failure) that you found. Just in case I have forgotten something that's important.
04-08-2019, 05:31 PM
#49
A couple items,
Inspect and re-silicone all edges every year, The snap in covers on all the edge trim is cheap and cracks easily letting water in. He recomended pulling all of it, hitting each screw head with silicone and then replacing with heavy duty trim like this:
https://www.amazon.com/RV-Designer-E...s%2C301&sr=8-2
Also said the roofs are super cheap and will only last a few years, Inspect and re-seal regularly.
Last one was AC, there are 4 nuts holding it on, snug them up every year to prevent leaking around the AC,s as the foam compresses.
04-08-2019, 09:03 PM
#50
A couple items,
Thank you , yes that trim is there to hide the screws , but it also hides where water can get in ,and I didn't know about the the AC unit getting loose.
04-09-2019, 10:09 AM
#51
Update: Repair will be delayed. Original plan was to replace rear skin, further investigation has determined that full wall(inner and outer were compromised) 6 week delay on getting the rear wall shipped to CA. Ill pick up the trailer this week and start my trips with it as it until all the parts are received.
04-09-2019, 10:57 AM
#52
I'm afraid you are in the infamous "delay mode" I hope this isn't just the start to it. I would of held out for it to be returned to Indiana. I would worry about the parts and panels being shipped across Country. There will be without a doubt some large pieces. Trucking companies aren't always the most careful with awkward and over sized freight.
I wish you luck and keep us informed.
08-27-2019, 01:57 PM
#53
Its been four months since my last update and I am happy to say, It is done and I have my trailer back! Great job by Mike at NorCal RV Body in West Sacramento. I realized real quick that living on the west coast is not best for timely repairs as every order takes weeks to receive and the process takes some time as more discoveries were made as the work was being done.
Nate
2018 Rockwood 2902WS Ultra Light
2018 Ford F-250 CCSB 6.7 PSD
Leer 100XQ truck cap
08-27-2019, 02:25 PM
#54
Five months... not bad. That's how long it took for mine, but then they had it over the winter season.
Safe and happy travels.
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2021: 19
Days camped 2020: 18
Days camped 2019: 17
08-27-2019, 03:07 PM
#55
so how do you feel about the repairs? do you think they will be 'like new'? it looks good in the picture. i had some body damage repaired by a reputable rv body shop and i have absolute faith in their repairs.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
08-27-2019, 03:26 PM
#56
Very high quality work. He even beefed up the studs behind the ladder and it has zero flex against the body when I climb up. Much better than stock
Nate
