Old 10-16-2016, 10:25 PM   #11
Originally Posted by Ozziedodge67 View Post
Check breaker and it is on, so I assume the element is nice and toasty...
My buddy knows how to do it( owns a few RV's)
My question is I have looked for a serial number and don't see it... it's a suburban unit
It's in a 2015 20pack10 wolf pack...
There should be a model number somewhere on it. I've attached the owner's manual that covers the most popular models.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 10-17-2016, 02:57 PM   #12
SW6DE is the unit...
I bought a new element $35 not bad
Does the water heater switch have to be on as well as the outside electric switch???
16' Cherokee wolf pack 20pack10
Rzr 1000
Outlander 1000
ĽAll pulled by 15' Gmc 2500HD duramax
Ozziedodge67 is offline   Reply With Quote
Old 10-17-2016, 03:30 PM   #13
Any one???
Rzr 1000
Outlander 1000
Old 10-17-2016, 04:57 PM   #14
wmtire's Avatar
Any one???
Ozzie, it's all explained in the link I provided in post #2 about the electric switch.
2011 Flagstaff 831 RLBSS
Yayy !!! I Won employee of the month again....I just love being self employed.
Old 10-17-2016, 05:09 PM   #15
KyDan's Avatar
We have info in the FAQ area about water heaters!
Read it!!
You can get a 120v 1500 watt screw in heater at Home Depot for under $10.
Here's one for $7
1500-Watt 120-Volt Screw-In Type High Watt Density Water Heater Element-15896 - The Home Depot
Two important things to remember when shopping for a HW heater at Home Depot, hardware store, Lowes etc... You most likely need a 120 Volt and 1400 or 1500 watt.
(Large 50 amp service seasonal trailers might use a 240 volt so you have to check!)
Peace!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-44, 2017-36
Old 10-17-2016, 07:38 PM   #16
I have read it.
If I have electric switch outside on do I need the water heater switch on? Or only if I want to use both
Rzr 1000
Outlander 1000
Old 10-17-2016, 10:37 PM   #17
RJJ
Outside switch runs electric element. Inside switch runs propane to heat water. Use one at a time or both. Each switch controls a different source to create hot water.
2015 Georgetown 329DS
2014 Chevy Equinox
RJJ is offline   Reply With Quote
Old 10-18-2016, 08:08 AM   #18
KyDan's Avatar
My last 3 trailers had the outside "hidden" switch for the electric heater.
Since I hated going out there to switch it I turned it off and on with the
circuit breaker inside. The outside switch eventually stuck on in my last
trailer. I didn't care because I used the breaker.
My current rig has 2 inside wall switches- one for LP gas hot water and one
for electric hot water.
This is why I hesitated to give you a definitive answer. I didn't figure it would be helpful to tell you "maybe" to your question!
Happy camping!
Peace!
Dan & Rita D
Old 10-18-2016, 11:20 AM   #19
If you only have the outside switch for the electric heating element and you either get tired of going outside to use it and you don't want to use the circuit breaker, you can install an inside switch like I did. See pics and wiring diagram. Note in the first pic I replaced the electrical box that the water heater plugs into because you need to install a "real" duplex outlet instead of that crappy RV style they use.
ID:	123324   Click image for larger version
ID:	123325   Click image for larger version
ID:	123326   Click image for larger version
hot water, water
